Old April 30, 2011, 12:34 PM
+ >9000 to AkG for the generous donation to OP.
Old April 30, 2011, 02:23 PM
francisw19's Avatar
Generous donation, indeed!
Old April 30, 2011, 05:14 PM
PerryC's Avatar
AkG, you are out of your mind...thanks very much. It was only 4 times to the sandbox though, spent 6 months in '04 visiting the tropical destination of Haiti. Been trying to get back over on the training mission, but so far no dice What can I say...I love my job.
I am looking at having 6 x 120mm fans, or 5 x 120mm and a 140mm in the side in that 912. 3 or 4 of them might be LED, not sure yet. Like I said I am not worried about noise. I don't play any games where its an issue. Any suggestions on a decent fan controller? Still not sure I am going to bother with one, but it never hurts to research the options.
Old April 30, 2011, 05:22 PM
Make sure you have an efficient power supply in order for you pc to run smoothly and not blow up :) You might want to invest in a electricity usage monitor to determine the amount of wattage your system is using.
Old May 1, 2011, 01:50 AM
lamptron are over engineered,built like tanks.
on the cheap,sunbeam 4 knobbers can be had for under 20 shipped sometimes.
New build long overdue Toyoracer New Builds 21 June 9, 2010 07:38 PM
First build in a long time lastsplash New Builds 3 November 8, 2009 09:12 PM
A long term new build andynerd New Builds 11 May 27, 2009 01:20 PM
New build in a long time!!! Delavan New Builds 7 April 10, 2009 07:09 AM
New Build, psu doesnt provide long enough cables! element291 Troubleshooting 3 January 13, 2009 04:13 PM
