Old April 23, 2011, 08:01 PM
Talking Thats it!!! FINAL BUILD!
Finally i decided to choose this one from the 2 builds i built
CPU:
CORE I7-2600K
CompUSA.com | BX80623I72600K Bundle | Intel Core i7-2600K CPU and Shogun 2 Game Download
MotherBoard:
P67A-UD4 של GIGABYTE
CompUSA.com | GA-P67A-UD4-B3 | GIGABYTE GA-P67A-UD4-B3 Intel 6 Series Motherboard
PSU:
TX-750W CROSAIR
CompUSA.com | CMPSU-750TX | Corsair TX750W 750-Watt Power Supply
Video Card:
HD6950
CompUSA.com | 100312SR | Sapphire Radeon HD 6950 2GB GDDR5 PCIe 2.1
Memory:
CROSAIR 2X4GB
CompUSA.com | CMZ8GX3M2A1600C9B | Corsair Vengeance 8GB (2x 4GB) DDR3 Memory Kit
CASE:
HAF932 ADVANCED
CompUSA.com | RC-932-KKN5-GP | Cooler Master HAF 932 Advance ATX Full Tower Case
DVD burner:
ASUS BURNER:
CompUSA.com | DRW-22B3S/BLK/G/AS | Asus 22x Internal PATA CD/DVD Drive
COOLER :
NACTUA NH-14
CompUSA.com | NH-D14 | Noctua NH-D14 CPU Cooler
HDD:
HDD WD CAVIAR BLACK 1.5TB
CompUSA.com | WD1502FAEX | WD Caviar Black 1.5TB SATA HD 7200/64MB/SATA-6G
$1,379.91(costs)
A few questions,
will this build work? will it run awesome? can it handle all the games today (BBC 2 and 3 in the future, GTA IV , CRYSIS 2 ?)??
If you could giva me a score for my PC, between 1-10, what would it be?
Old April 23, 2011, 08:15 PM
I'd give it a 6.5 maybe 7.
What about getting a modular power supply?
"What is the colour when black is burnt ?" - Neil Young
Old April 23, 2011, 08:49 PM
Alpine's Avatar
+1 for a modular cable PSU
• ► › I7 3930K|Asus P9X79 WS|Evga GTX 690 Signature|Corsair Force 3 120GB|Corsair H1000|Corsair Dominator Platinium 16GB 2133Mhz|
Corsair AX1200|Corsair 600T SE|Corsair SP2500|Corsair Vengeance 2000
• ► › I7 2600K @ 4.9Ghz|P67A-UD4-B3|12G G.Skill 1600Mhz|Noctua NH-D14|OCZ Vertex 2 60GB|EVGA GTX 580 SSC|Corsair AX650|Lancool PC-K62|
Old April 23, 2011, 11:35 PM
You could get version 2.0 of the TX750 for the same price. -1
Your Vengeance RAM kit will not fit on your motherboard with the NHD14. Go for low profile heat sink RAM kit. I recommend Kingston. -2
I know that the HAF 932 has an updated version with USB. 3.0 and newer fans. -1
i7 2600k? Meh. Your other parts are value oriented while the CPU isn't. i5 all the way. -1 because as a gamer, if I'm going to blow money away, first I'd get more video power.
+1 for considering future CF with 750w and UD4
6/10. Hope that helps and good luck!
Old April 23, 2011, 11:53 PM
hmm..maybe a 500gb black for os and a 2tb green for storage?
2500k as well.
hr-02 for cooling
and maybe a 922 or 912 for case. theyre smaller than the 932,dont take as much space but still fit anything :D
Old April 24, 2011, 04:14 AM
fishingfanatic's Avatar
Smile New Build
+1 4 the modular psu. I would change your DVD 2 sata instead of pata.
Gpu is a personal choice, however consider an Nvidia product 4 overall better driver support.
Consider also, getting a 1tb black and adding a small SSD 4 your OS. The V 2 is a great drive from OCZ.
That will be the fastest 4 startup and they're much cheaper now.
Choice of case is subjective at best. Since you're already getting a full tower, consider the HAF X 4 the usb3
and sata3 support.
It also comes with a gpu fan shroud which I use and it helps considerably with 2 480s in sli.
Looks like a good system! Enjoy the build and results.
Old April 24, 2011, 06:26 AM
Question
ahhh so it wont work??? I need to change something?
you said that the ram wont fit into my mother board because of the heatsing of the CPU...what if i remove the heatsink,stay with the normal, the ram will fit?
well you said that all other parts are value while the CPU isnt, So thats mean that it will be bottlenecking???
Old April 24, 2011, 06:46 AM
also when in doubt,lookie here :
AMD Radeon HD 6950 1 GB Review - Page 22/26 | techPowerUp
Old April 24, 2011, 07:02 AM
By value I meant worth your money or not, and as a gamer, I find little worth in the extra $100 for the i7 2600k. Neither sandy bridge CPUs nor dx11 GPUs will bottleneck each other. They complement each other rather well, but you will notice drop in frame rates if you go below i5
RAM will fit with the normal heatsink as well as other certain models. If you can do without the Vengeance, this is a list of RAM kits and their compatibility with the NHD14:
DDR3 A-Data G-Series
DDR3 A-Data G-Series ver2.0
DDR3 A-Data Plus-Series
DDR3 A-Data Plus-Series ver2.0
DDR3 A-Data Standard- / Value-Series
DDR3 A-Data X-Series
DDR3 A-Data X-Series ver2.0
DDR3 Corsair Value-Series
DDR3 Corsair Vengeance
DDR3 Corsair XMS3 DHX Series
DDR3 Corsair XMS3 Dominator Compatible when the heatsink on top of the heatspreader is removed.
DDR3 Corsair XMS3 Dominator GT Compatible when the heatsink on top of the heatspreader is removed.
DDR3 Corsair XMS3-Series
DDR3 Crucial Ballistix
DDR3 Crucial Ballistix (Tall Heatspreader)
DDR3 Crucial Ballistix Tracer
DDR3 Elixir Standard Series
DDR3 G.Skill ECO Series
DDR3 G.Skill Flare Series
DDR3 G.Skill PI Black Series
DDR3 G.Skill Ripjaws
DDR3 G.Skill Ripjaws X series
DDR3 G.Skill Sniper Series
DDR3 G.Skill Trident Series
DDR3 Geil Black Dragon Series
DDR3 GeIL Gaming EVO ONE
DDR3 GeIL Green Series
DDR3 Geil Ultra Plus
DDR3 GeIL Ultra Series
DDR3 Geil Value Plus
DDR3 GeIL Value Series
DDR3 GeIL XMP EVO ONE Series
DDR3 GeIL XMP Ultra Series
DDR3 Kingston HyperX
DDR3 Kingston HyperX Genesis
DDR3 Kingston HyperX H2O
DDR3 Kingston HyperX Tall HS
DDR3 Kingston Value-Series
DDR3 Mushkin Blackline
DDR3 Mushkin Essentials
DDR3 Mushkin Proline
DDR3 Mushkin Radioactive Series
DDR3 Mushkin Redline
DDR3 Mushkin Ridgeback
DDR3 Mushkin Silverline
DDR3 OCZ Blade 2 series
DDR3 OCZ Blade Series
DDR3 OCZ Fatal1ty Series
DDR3 OCZ Flex XLC Series
DDR3 OCZ FlexEX
DDR3 OCZ Gold Series
DDR3 OCZ Intel Extreme Series
DDR3 OCZ Limited Edition Series
DDR3 OCZ NVIDIA SLI-Ready Series
DDR3 OCZ Platinum Series
DDR3 OCZ Reaper Series
DDR3 OCZ Titanium Series
DDR3 OCZ Value Series
DDR3 Patriot Bladed Series
DDR3 Patriot Gamer 2 Series
DDR3 Patriot Gamer Series
DDR3 Patriot Signature Line
DDR3 Patriot Viper II Series
DDR3 Patriot Viper Series
DDR3 Patriot Viper Xtreme Series
DDR3 Super Talent Black Series
DDR3 Super Talent Chrome Series
DDR3 Super Talent Desktop-Series
DDR3 Super Talent Extreme Performance Series
DDR3 Super Talent Gold Series
DDR3 Super Talent Project X Series
DDR3 Super Talent Speed Series
DDR3 Team Group Elite Series
DDR3 Team Group Xtreem Dark Series
DDR3 Team Group Xtreem Series
DDR3 Transcend aXeRam
DDR3 Transcend Jetram
compatible possible issues (see comment) incompatible (see comment)
Source:
Noctua.at - sound-optimised premium components "Designed in Austria"!
Old April 24, 2011, 07:03 AM
thankx man!!! u helped me!!! alot!!!
Tags
builddddddddd
Complete and Final build Crysisfan11 New Builds 6 May 23, 2009 11:05 PM
New build, need final opinions Mavvens New Builds 21 March 17, 2009 05:39 PM
i7 Final Build ev0styLe New Builds 15 January 18, 2009 07:40 AM
Final Build, With Some Changes.... mlauzon New Builds 23 December 10, 2008 12:04 PM
final build xghostz New Builds 8 October 19, 2008 05:41 AM
