  #21 (permalink)
Old April 28, 2011, 05:55 AM
Originally Posted by Keltron 3030 View Post
So after doing some looking around...
2) Arctic Cooling ACALP64
Note that's an AMD-only cooler. IIRC the OP built a rig with an Intel 2500k?
  #22 (permalink)
Old April 28, 2011, 06:31 AM
lastsplash's Avatar
Will a Corsair H60 fit in a SG07? I've got an H50 in my SG05, works well.
  #23 (permalink)
Old April 28, 2011, 12:12 PM
the SG07 uses a 180mm instead of a 120 so no, unless you mod/just leave it hanging...part of the reason y i personally rather the SG05...
Ultra clean Small Form Factor PC Mnpctech Off Topic 6 April 21, 2011 06:45 AM
Simple Office PC - Small form factor bonanza2000 New Builds 23 February 15, 2011 05:24 PM
Small Form Factor i7 jak3_dude New Builds 12 June 22, 2009 10:18 PM
