Old April 22, 2011, 09:41 AM
Thanks sorry for no pics for a week!
I had 3 BSOD so I didn't tie things up... I had to figure how to use the debugger for mini dumps.
Then I found the solution in these forums
Intel Gigabit Ethernet adapter was the cause
That's a Thermal Sensor I have stuck to the Rad on the H70 ( mobo has 3 that I put around the parts, 1 more in ram and the other verifying the NB temps)
I will be doing cable management later today!
Old April 22, 2011, 09:43 AM
coleo's Avatar
is there no way for you to make you H-70 exit the case instead of blowing the heat into the case?
Old April 22, 2011, 09:56 AM
I was wondering that as well but Corsair recommends that the user blows inwards instead of the usual method as cold air from the outside can be used to cool the rad better. The flaw of this method by Corsair is that it will increase case temps and more exhaust fans would be necessary. OP should mount exhaust fans on the top of the casing if there is none.
Old April 22, 2011, 10:11 AM
chrisk's Avatar
Folding Captain
Nice rig! The Haf-x is a great case for air cooling.
There is a big 200mm fan at the top by default, and if you are using the rear fan as an intake (the Corsair cooler), then you should ensure that the 200mm fan is an exhaust. I just read a review (Neoseeker) saying it was intake by default, so I would double check.
Fold for team #54196
Old April 22, 2011, 11:31 AM
very nice rig .congrats.
Haf-X is a superb cabinet .
try to post more pics after completing cable management
Old April 22, 2011, 04:35 PM
bf1 bf1 is offline
sweet build dood, looks great, could use some cable management but awesome
Old April 23, 2011, 01:13 PM
canada2005's Avatar
Yup good build, but work on that cable management.
ASUS ROG Crosshair IV Extreme xlilmissmjx Rumor Mill 17 October 25, 2010 02:43 AM
ASUS Launches ROG Crosshair IV Extreme Motherboard FiXT Press Releases & Tech News 12 October 5, 2010 08:46 AM
ASUS ROG Crosshair IV Formula and Extreme MarkOne Press Releases & Tech News 0 March 2, 2010 08:37 AM
My HAF 932 - Paint & WC bkh2 Cases 12 December 9, 2009 03:37 PM
