Originally Posted by tabasko The i3 will run netflix videos.
Caviar greens are slower/use less power (use for storage). Blacks are high performance (use as boot drives). Blues are in between.
As for the motherboard, if you don't have anything for the PCI slots, a smaller motherboard will be cheaper and do the job. |
Ya he might eventually want to put a discrete video card in so ill prob stay with a regular size mobo.
Looks like caviar blues are very close in price so I'll swap that as well.
Another question, he has a really old computer right now (like 8+ years old) which doesn't work and I was wondering can I remove the harddrive in there and be able to install it in this new one and just grab the data off it? It's prob a real old Sata 1 hd
