Old April 8, 2011, 07:51 AM
Originally Posted by Perineum View Post
Consider Windows Home server, it's the cheapest easiest way of doing this, just a bit hard on HD space.
I'll beg to differ.. The cheapest and easiest way of doing it is with FreeNAS.
I setup a 3TB NAS with the software and the ONLY issue I ran into was because I was using a shitty onboard network card.
Old April 8, 2011, 08:19 AM
Perineum's Avatar
Sorry, I didn't mean to say cheapest. Of course a free linux based software is going to be cheaper.
However I still think it's the easiest.
For a person that doesn't know RAID or anything like that then WHS is just simple
Old April 8, 2011, 09:34 AM
botat29's Avatar
+1 , and if the motherboard fail the OP can always install his drives in a PC to retrieve the info.
Old April 8, 2011, 11:56 AM
BlueByte's Avatar
I use atom boards for a lot of home projects, something like a Zotac with 5 or 6 sata ports and your laughing down the road for expansion. IF your unsure of RAID and looking to replace a 2TB setup, just RAID 1 them and it does not matter what controller you put them on if the NAS ever fails. RAID 5 or 6 and you should have an external drive backing up your important stuff... RAID should not be used as THE backup, its only good as a fast fix for a failed drive or speed. Its very possible to have a RAID array fail, especially as we move to larger and larger drives.
Old April 8, 2011, 12:06 PM
I like this idea as well. My main thing is always being able to get my data and have a bit of fault tolerance in case a drive were to fail, especially when 2TB drives are so cheap, but when one fails, it can mean massive amounts of data. Which WHS is sounding more and more appealing.
thinking about WC lcdguy Water Cooling 4 July 1, 2010 09:17 AM
thinking about upgrading soon... derkaderka Video Cards 2 June 9, 2010 08:56 PM
Thinking of Building a Folding Rig Goalieman077 HardwareCanucks F@H Team 38 November 18, 2009 11:57 AM
Not sure what I was thinking but...... kruzn4evr Display Units 42 March 9, 2009 06:48 PM
So Im thinking about upgrading tgraszat14 Video Cards 4 May 13, 2008 04:31 PM
