Old April 3, 2011, 05:43 PM
botat29's Avatar
Default WHS Build
1. What YOUR PC will be used for.
Host Windows Home Server
2. What YOUR budget is.
Less posible
4. IF YOU have a brand preference.
Will go with a AMD ( I like when it's posible to help AMD a little bit)
Only the case
Tomorrow
9. What resolution do you use?
let's say I will not play Crysis with this one....
Ok, for the board I plan to use a GA-890GPA-UD3H or a M4A88T-V EVO or a M4A89GTD PRO , it's the CPU I don't know, an Athlon will cost me $ 60 and a Phenom $ 100, I guess as a files server an Athlon is ok.
So witch board is the best, and is it ok an Athlon
NOTE , that a Asus M4A78LT have the 6 sata I need , but the board do not have heatsink over the volrage reg. , is it important ? because I will save another $ 50
Old April 3, 2011, 05:56 PM
either asus or giga 880/890 will the jobbe well, you dont need anything special.
cpu wise, a duallie will do but throw a quad in just in case.
since you wont be clocking or anything, do save.
ps if you were to build intel i3 (1155/56) youd be better off but hey.well except for the onboard gpu.
Old April 3, 2011, 06:04 PM
botat29's Avatar
Originally Posted by _dangtx_ View Post
........but throw a quad in just in case.
in case of what ?
this build will never see other usage than WHS,
Old April 3, 2011, 06:05 PM
ok then go for the cheapest athlon II you can find then :)
Old April 3, 2011, 06:07 PM
botat29's Avatar
I look also at a 775 build but the ddr2 are very expensive
Old April 3, 2011, 06:11 PM
celly 3300/3400 are a great bang per buck, better on power figures than their athlon counterparts.
you can find 50-60 dollar ddr3 mobos that wil ltake them, with gma4500 video onboard.
Old April 3, 2011, 06:14 PM
botat29's Avatar
do you have a board in mind, the only ddr3 I found are Pxx so no onboard, and I need 5 sata
Old April 3, 2011, 06:18 PM
one sec...
edit
ASUS P5G41T-M/CSM LGA775 mATX G41 DDR3 PCI-E16 PCI-E1 2PCI HDMI VGA GMA4500 Motherboard - DirectCanada
Gigabyte GA-G41MT-D3 mATX LGA775 G41 DDR3 1PCI-E16 2PCI Video Sound GBLAN Motherboard - DirectCanada
as for the number of sata ports....hmmm....
Old April 3, 2011, 06:40 PM
botat29's Avatar
I may be ok with 4 sata ( 1 for the OS and 2 x 2TB, for a total of 2 gb with folder duplication ) and add a sata add on card if needed later
but for $ 40 more I have an AMD solution with 6 sata + IDE , I can even put a IDE as OS and use 6 x 2 tb ( for a total of 6 tb since I duplicate all the folders )
I'm not at $ 40 near, So i guess the AMD will be my choice, what about a Semptron ? ( not sure about how much CPU power folder replication need )
and what about those voltage regulator heatsink
Old April 3, 2011, 06:53 PM
botat29's Avatar
what about those thing
Newegg.ca - ASUS E35M1-M PRO AMD Zacate E350 AMD Hudson M1 Micro ATX Motherboard/CPU Combo
EDIT : not sure I will not have problem with the driver with WHS ...
WHS 2011 RC now available , MS just sentence WHS to death botat29 Press Releases & Tech News 7 February 3, 2011 02:28 PM
WIP RM WHS lcdguy Case Mods, Worklog & Gallery 18 December 16, 2010 10:16 PM
Raptor to whs?...... rob123 Storage 8 December 7, 2010 02:15 AM
ITX WHS Build recommendations - 1156/i3/6HD's/Small Case Shftup New Builds 12 June 24, 2010 03:43 AM
antivirus for WHS....... rob123 O/S's, Drivers & General Software 2 February 22, 2009 07:53 AM
