Old April 1, 2011, 11:44 AM
Originally Posted by BMAN69 View Post
I see that over at NewH4rd; the price for an AMD HD6870 Toxic, is about the same as what you're paying for the NVidia GTX 560 Ti, not trying to push AMD or anything, would this suit your needs SAPPHIRE TOXIC Radeon HD 6870 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support
560ti > 6870 so yeah...no!
Old April 1, 2011, 11:56 AM
Soultribunal's Avatar
My only suggestion, is grab Corsair or Antec for the PSU. Avoid the OCZ and CM ones.
Otherwise although the cost and warranty of things is obviously different for you there. (ASUS is 3 years in Canada here). Grab whatever has the best warranty coverage
And The 6870 and 560 are pretty close in terms of performance. Though I find nVIdia's driver support to be light years ahead of ATi.
ST
www.realhardwarereviews.com
Old April 1, 2011, 12:46 PM
Thanks for all the feedback guys !
Is antec earthwatts good ? should I go for 650W(140 u$s) or 750W(180u$s) ?
Old April 1, 2011, 12:55 PM
Both would work for your rig very well as the 650W is enough to support GTX560 Ti dual SLi and the 750W is overkill for a GTX560 Ti dual SLi. If you are willing to have a 100W extra headroom get the 750W but at a premium of $40.
My choice would be with the 650W which I find it sufficient even if you decided to run the Core i5 2500K at OC speeds 24/7.
Old April 1, 2011, 01:05 PM
In my own eyes, I would suggest getting the 750, it will run cooler beacuse it won't be closer to its max output (not that your setup will majorily stress a 650). But the Extra headroom is always nice to have.
ST
Old April 1, 2011, 01:39 PM
go with the 650, you can do a lot on 500 something watts on the 12v rail :)
Old April 1, 2011, 01:42 PM
Guess Im going for 750W just to be safe If I want to upgrade something :), Thanks Guys for all the feedback.
Awesome Forum, Really happy I came here.
I guess I have to thanks linustechtips :p
5 2500K
P67A-UD4
4GB Kingston HyperX 1600Mhz CL9 1x4 (I will get one more in a few weeks)
Gtx 560 Ti Twin Frozr
Lancool K62 case
WD Caviar Black 1TB 64mb
antec earthwatts 750W
Edit: If I can find a Corsair 750W TX for the same price should I go Corsair > Antec ?
Old April 1, 2011, 11:42 PM
Only if you could find a Corsair that is priced the same with Antec at 750W. If you couldn't find or don't want to find it then the Antec would do just fine.
  #19 (permalink)
Old April 2, 2011, 07:31 AM
Hey Guys Found some Corsair PSUs, Can you tell me which one is the best options ?
Corsair Enthusiast TX Series CMPSU-650TX V2 150 u$s
Corsair Enthusiast TX Series CMPSU-750TX V2 195 u$s
Antec Earthwatts 650W 140 u$s
Antec Earthwatts 750 190 u$s
Thanks for all the feedback :)
  #20 (permalink)
Old April 2, 2011, 07:41 AM
the earthwatts were made by either seasonic(same as some corsairs) or delta. either or solid units.
and the corsairs are good,of course.
i would go with the 650 v2 perhaps, although the earthwatts are quieter, in my humble opinion
To build, or not to build: that is the question Timid newbe New Builds 5 August 12, 2010 04:33 AM
New Build- Corsair 800D --> My cleanest build ever. Watercooled btdvox Case Mods, Worklog & Gallery 28 May 11, 2010 01:07 PM
Windows 7 Build 7000 VS Windows XP SP3 Build 2600 Benchmarks Veritas Overclocking, Tweaking and Benchmarking 3 March 3, 2009 02:48 PM
