  #21 (permalink)
Old May 4, 2011, 04:48 AM
^ Yes that is a good choice. Pretty cheap for a 4GBx2 kit compared to the other DDR3 listed.
  #22 (permalink)
Old May 4, 2011, 10:41 AM
What exactly will you be doing with your computer? It seems like you may be spending way more than you have to. At the same time, you'll be producing more noise and heat than I think you're really after.
  #23 (permalink)
Old May 8, 2011, 12:49 AM
Before I made my PC louder than a jet, I had a Noctua NH-U12P in my Antec 902 case and it was completely silent. The new revision is apparently even better.
  #24 (permalink)
Old May 13, 2011, 01:26 AM
Thanks for answers, I started this searching for a very quick and silent computer. I know about the conflict between thoose two, and that the programs Im going to use are not that advanced. Still, I spend a lot of time by the computer and I want good silence and speed.
HD Speed Nerdy Storage 6 December 30, 2010 05:34 PM
My Antec 300 on its way to Silence and Performance CoolHandL Case Mods, Worklog & Gallery 12 April 16, 2010 08:33 AM
Apple tried to silence family over exploding iPod badatcards Off Topic 19 August 4, 2009 03:08 PM
Speed up your internet... Squeetard Networking 14 January 13, 2009 12:31 PM
timings vs. speed Mr. Cipher RAM 22 February 15, 2008 05:07 PM
