If you don't game much and don't plan on overclocking, I would go with what Luay said and get something cheaper. Also, 8GB of RAM is too much if you're not doing anything graphics intensive. Decent 4GB kit is all you need. Shazam, Corsair can't go wrong:
NCIX.com - Buy Corsair XMS CMX4GX3M1A1333C9 4GB 1X4GB DDR3-1333 CL9-9-9-24 DIMM Memory Module - Corsair - CMX4GX3M1A1333C9 - in Canada. As for a cooler, a CM Hyper 212+ is super cheap and is very decent when it comes to noise. You don't need to run it on full but it's the best $20 you'll ever spend on a CPU cooler. Your case is nice so should help with what little noise it does make. If you won't be OCing or anything don't worry about noise. Also, don't forget to pricematch your parts too. You can save tons of cash.
