Old March 15, 2011, 02:02 AM
Originally Posted by Heartattaq View Post
Another question, I currently have
NCIX.com - Buy OCZ B-Stock Refurb StealthXStream 600W ATX12V 24PIN ATX Power Supply 120MM Fan Black - OCZ Technology - OCZ600SXS-B - in Canada
that PSU in my old case. would it be sufficient to run the sytem I am currently wanting to put together or should I just upgrade now?
Yes, and you still have room.
Old March 15, 2011, 06:27 AM
That's great news. If I can recycle the case and psu, I can shift some more money to other items.
I think the CPU and HDD are fine, but maybe there is a better mobo out there. So in the dark about mobo's so many choices out there.
I know I wont be going SLI, and I want room for expansion. Hmm
Old March 15, 2011, 06:30 AM
Also Since I wont be overclocking would the stock cooler suffice?
If not I have read good things about the corsair H70, would anyone recommend it?
I have a
NCIX.com - Buy Zalman CNPS9700LED CPU Heatsink 110MM Fan LGA1156 1155 775 AM3 939 940 754 1250-2800RPM Blue LED - ZALMAN TECH - CNPS9700LED - in Canada
on my current cpu unfortunately, the person that built the pc for me, didnt give me the extra brackets, so I dont think it will fit my new cpu
Old March 15, 2011, 12:48 PM
if you aren't overclocking the stock cooler is fine. If you really want to shift more oney into that build the best things for you to upgrade are the mobo and GPU everything else in that build is super solid.
Old March 17, 2011, 04:01 PM
Alright order is going in tomorrow, and this combo deal just came up on NCIX,
im already getting the processor, but is this MoBo, satisfactory? As I said already, I am really in the dark about which type of mobo to buy
New Rig Buying Next Week. gambel626 New Builds 9 July 18, 2010 06:54 PM
Buying in one week LacrosseTown New Builds 19 May 31, 2010 05:05 PM
Buying PC Parts from the US Goalieman077 Off Topic 8 October 14, 2009 12:22 PM
Case buying advice! raheelc Cases 8 July 24, 2009 01:24 PM
New to OC and buying a new system... need advice Spblue Overclocking, Tweaking and Benchmarking 3 December 5, 2007 10:21 AM
