Old March 11, 2011, 07:00 PM
Default MythTV HTPC build -is PSU ok?
Just looking for any thoughts on this sub-$700 HTPC build to be used for handling OTA TV via MythTV. Realize it's not an HTPC case, but it's a small tower and a good price. Still need to find a good IR remote that works well with MythTV. Looking to buy in the next week or so.
I'm not 100% sure about whether the PSU is strong enough so really need input there. (one day it'd be great if a site like NCIX had enough info in it's database to make PSU suggestions. :) )
Motherboard: Gigabyte GA-M68M-S2P mATX AM2+
CPU: AMD Athlon II X2 250 Dual Core Processor Socket AM3 3.0GHZ 2MB L2 Cache 65W Retail Box
Memory: G.SKILL F2-8500CL5D-4GBPK PC2-8500 4GB 2X2GB DDR2-1066 CL5-5-5-15 240PIN Dual Channel
HD: Western Digital WD Caviar Blue 1TB SATA 6GB/S 7200RPM 32MB Cache 3.5IN Hard Drive OEM
Case: Coolermaster Elite 342 Black M-ATX Mid Tower Case 2X5.25 5X3.5INT 1X3.5EXT No PSU
PSU: Corsair Builder Series CMPSU-430CX 430W ATX Power Supply Active PFC 120MM Fan
DVD: Liteon IHAS124 24X DVD Writer SATA Black OEM
Video: ASUS GeForce GT 430 700MHZ 1GB 1.6GHZ GDDR3 PCI-E DVI VGA HDMI Low Profile Video Card
TV Tuner: HD HOMERUN Dual Tuner
Thanks and have a great weekend.
Old March 11, 2011, 07:07 PM
hmm...try to get the 400, and yeah itll be more than enough. you wont bereak 175 watts
you could also give h55 a try you know, smal ldifference in price. of course itll need ddr3.
the gt430 might be too much for it. im thinking the onboard gpu could handle videos well enough.
Old March 11, 2011, 08:10 PM
Wi-Fuzzy's Avatar
I have a HTPC. I run WMC with MyMovies 3 plugin and a few others. Here are my thoughts on what you need based off of 2 years of tinkering. It is all about silence with a HTPC. You want a fanless video card , PSU and CPU cooler. get the lowest watt CPU you can, I think the one you have is fine. You only need 2 Gigs of ram...spend the money somewhere else. A good CPU cooler with no fan (tower type) case fan will cool the cpu. There are quite a few video cards whith fans that are very quiet...but fanless is the best. Fanless PSu are out there. You won't need much power for this system anyway. Don't forget a cooler for the HD. It will work failry hard and need cooling. I know I didn't answer you question...450 watts would be lots. Onboard video is not a great idea for HTPC...you may want to add a bluray or play dvds later...the vid card will be beat at handeling that.
Old March 11, 2011, 10:41 PM
biff's Avatar
+1
I have two of the 400's and one of the 430's and prefer the 400's. Not much difference really but the 400 is a little bit more quiet. Well the 400's are silent and I can just barely hear the 430 but I'm really anal about sound from HTPC's.
i7 4790K @ 4.8GHz w/EK Supremacy Evo
MSI z97 Gaming 5
2x 8GB Gskill Sniper 2133 @ 2400MHz
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Still rockin' the Cooler Master Cosmos on water
Old March 12, 2011, 12:28 AM
Looking at some of the MythTV info, I see that 4GB might be overkill.
Just curious looking at the memory list and trying to see what 1 gig sticks would work to make 2 gig.
Is the KHX8500D2/1G listed in http://download.gigabyte.us/FileList...-s2p_v.2.3.pdf the same as the Kingston HyperX KHX8500D2K2/2G I see listed on some sales sites?
Tags
mythtv :http:c
[WTB] HTPC parts (GPU, CASE, PSU, HDD, DVDRW, RC possibly) undeclared Buy/Sell & Trade 4 September 18, 2010 09:05 AM
what is a good quiet PSU for my HTPC Shadowmeph Power Supplies 11 August 22, 2009 09:13 AM
[FS] HAF932, HTPC Case, Raid Card, 750 PSU ect... ikeenen Buy/Sell & Trade 13 May 1, 2009 09:08 PM
Yet another HTPC build- help? misterd HTPC Systems & Software 4 August 1, 2008 10:10 AM
HTPC Build Phobia HTPC Systems & Software 15 July 16, 2008 10:07 AM
