Old March 4, 2011, 12:05 AM
Smile system fans
Hi all
When building a new computer, does it matter whether one plugs the system fans into the the motherboard or directly into the power supply. I expect a bit of razzing for that question!
Old March 4, 2011, 12:18 AM
preferably into a fan controller, or the mobo which usually can control them too,
if they dont draw insane amounts of juice.
dont worry to ask, were here to help :)
Old March 4, 2011, 01:22 PM
If you run it into the PSU it'll run at max speed I believe. Depending on your fan, it could sound like a jet plane!
Old March 4, 2011, 02:01 PM
The stupidest question is the one you won't ask. Simply because you'll never know the answer.
Old March 4, 2011, 02:38 PM
rjbarker's Avatar
Plug em into whichever one is going to help you with Cable management and convenience, some times one or two directly into PSU is most convenient, toher times utilizing several Mobo Headers in more convenient.....as was mentioned directly into PSU means no Fan Control..(not a biggie in many cases)..
Firestrike Extreme: 21.452
MARK 11: 32.530
Old March 4, 2011, 04:09 PM
1) If you plug them into your motherboard, it will draw power from your motherboard and [on higher end boards] will control the fan speed for you. Power draw may be an issue on cheap mobos.
2) Plugging directly into the PSU provides a great power source, but fans run at 100% all the time.
3) Using a fan controller is like plugging it into your PSU (power wise) but lets the controller adjust the speed of the fans to provide best balance between performance/efficiency/noise.
Old March 5, 2011, 07:26 AM
Everyone, thanks! Totally appreciate it!
This is y first HTPC build and it is working great, only thing is that is sounds like a jet airplane! The reason I plugged the sys fanss into the power supply directly is that the case has 3 sys fans and the mobo seems to have only one header for a system fan. Is there a way to plug them all into that header?
Regards
Chris
Old March 5, 2011, 07:33 AM
sswilson's Avatar
What case are you using? (I'm assuming you're using the stock fans)
Folks with more tender ears than mine (26 years working with aircraft) will chime in with fan recommendations, but I'm personally still a fan (pun intended.... ;) ) of the 1350 RPM YLs as a bang-for-your-buck quiet fan.
Old March 5, 2011, 08:27 AM
Soultribunal's Avatar
I wouldn't daisy chain any fans onto a single header (I know it can be done) but still thats probably asking too much out of what it is (espically if the board is not higher end).
If your HTPC has room or a 5" bay I would invest in a fan controller as one option to help keep noise in check. Otherwise a good Case fan to use would be the Gelid TC Fan.
NCIX.com - Buy GELID Solutions GELID Silent 12TC 750-1500RPM 120MM Thermal Control Fan 58CFM 12-25.5DBA HDB 3PIN - Gelid Solutions Ltd. - FN-TX12-15 - in Canada
Used these on multiple silent builds and they have worked out fine thus far.
Regards,
ST
www.realhardwarereviews.com
Old March 5, 2011, 09:36 AM
The case is a Silverstone Grandia GD05 with 3 stock fans, and the motherboard is a MSI 890GXM-G65. The case does not have an extra 5 in bay. The specs I used came from a Maximum PC article, so I trust there is a way to do it.
I appreciate your interest.
Regards
Tags
motherboard , power supply , systems fans
[WTB] Fans. Lots of fans. gray mole Buy/Sell & Trade 1 December 29, 2010 02:20 PM
what fans should i get kuziwk New Builds 10 January 18, 2010 11:08 PM
[FS] New Zalman fans, used Scythe and blue LED fans mhw100 Buy/Sell & Trade 15 June 22, 2009 02:32 PM
Anyone have one of these fans? Realityshift Air Cooling 11 March 12, 2009 08:44 PM
Tutorial: Repair your noisy cpu, system and video card fans nork Guides & How-to's 11 March 16, 2008 10:03 AM
