Old March 5, 2011, 09:51 AM
Originally Posted by chriso View Post
The case is a Silverstone Grandia GD05 with 3 stock fans, and the motherboard is a MSI 890GXM-G65. The case does not have an extra 5 in bay. The specs I used came from a Maximum PC article, so I trust there is a way to do it.
I appreciate your interest.
Regards
If you find those fans to be loud at full RPM, the Gelids are going to be far worse for you.
I would recommend undervolting via the 7 volt trick directly from your PSU. Try that first, see if you find the noise acceptable, then check to see if the temperatures are ok. If both work out, you don't have to spend a dime.
You could also remove the fan filters, but then you'd have to clean out the dust every once in a while depending on how dusty your environment is. But with the fan filters internally mounted, you'd have to open your case every so often anyhow.
Old March 5, 2011, 11:51 AM
7 volt trick is the way to go! Try this first it will cost you nothing! If you don't know how to to it, here is a good link:
Get 12V, 7V or 5V for your Fans | silentpcreview.com
Old March 5, 2011, 12:03 PM
Slik's Avatar
Originally Posted by Soultribunal View Post
I wouldn't daisy chain any fans onto a single header (I know it can be done) but still thats probably asking too much out of what it is (espically if the board is not higher end).
If your HTPC has room or a 5" bay I would invest in a fan controller as one option to help keep noise in check. Otherwise a good Case fan to use would be the Gelid TC Fan.
NCIX.com - Buy GELID Solutions GELID Silent 12TC 750-1500RPM 120MM Thermal Control Fan 58CFM 12-25.5DBA HDB 3PIN - Gelid Solutions Ltd. - FN-TX12-15 - in Canada
Used these on multiple silent builds and they have worked out fine thus far.
Regards,
ST
I agree with Gelid. I have one and it is VERY quiet and is VERY good for cooling.
EVGA DG 87 -i7 5930k @ 4.4ghz. Liquid cooled-4x4gb G Skill Trident X DDR3@ 2400mhz- EVGA x 2 1080 Ti Black SLI - Soundblaster X7 Sound Card- LG 34" Monitor-ATH AG1X Headphones-Butt Kicker Gamer-TrackIR 5
Old March 7, 2011, 11:56 AM
I'm crazy about Noctua myself but they dont come cheap, otherwhise I love the Scythe S-Flex series.
Tags
motherboard , power supply , systems fans
[WTB] Fans. Lots of fans. gray mole Buy/Sell & Trade 1 December 29, 2010 02:20 PM
what fans should i get kuziwk New Builds 10 January 18, 2010 11:08 PM
[FS] New Zalman fans, used Scythe and blue LED fans mhw100 Buy/Sell & Trade 15 June 22, 2009 02:32 PM
Anyone have one of these fans? Realityshift Air Cooling 11 March 12, 2009 08:44 PM
Tutorial: Repair your noisy cpu, system and video card fans nork Guides & How-to's 11 March 16, 2008 10:03 AM
