Old February 24, 2011, 04:33 AM
slippy's Avatar
Default Cable Management
Is it safe to fold SATA cables?
Old February 24, 2011, 05:50 AM
JD JD is offline
I've never had any issues folding them. Just don't be too aggressive I suppose.
People commonly curl them as well without issues.
Old February 24, 2011, 05:53 AM
They're technically not supposed to bent past a 90 degree angle.
However, manufacturers fold them up for packaging all the time, and I have yet to come across a DOA cable. I try not to bend them at sharp angles though, as the wires inside are a little brittle.
Old February 24, 2011, 06:46 AM
This is ok:
http://www.atechfabrication.com/imag...Cable_data.jpg
This is also ok:
http://us.123rf.com/400wm/400/400/we...-in-spring.jpg
To twist a sata cable.. get a long screw driver, stick or whatever you have.. and then just twist it tightly around it.
Old February 24, 2011, 08:05 AM
slippy's Avatar
Thanks guys! I'm finding it hard to hide those bright blue Gigabyte SATA cables in my black case with no cheats (Elite 430)
Old February 24, 2011, 11:57 AM
EdHilario's Avatar
I've folded my SATA cables with no issues but I leave a pinky finger gap at the bend. Maybe less. lol
Cable Management Anyone? Arinoth Off Topic 16 July 8, 2010 10:04 AM
Cable Management Tips jcmaz Guides & How-to's 25 September 7, 2009 07:39 PM
Cable Management help EaGle1337 Troubleshooting 9 January 7, 2009 05:07 AM
Cable Management :D Inik Cases 6 March 17, 2008 06:21 PM
Just another Cable Management Thread low351 Cases 2 March 17, 2008 04:48 AM
