Originally Posted by chriso Hi - attached is a pic of the ram Crucial CT25664BC1067 2GB 2X2GB PC3-8500 DDR3-1066 204PIN SODIMM that I decided to buy - but it seems like I got the wrong thing as it does not appear to fit. The build MaximumPC specs called for 2 times 1 GB DDR3-1333.
My question is - would this work?
Thanks in anticipation.
Chris |
you don't get the wrong thing, you order the wrong thing, the one you receive are SODIMM I hope you don't power the board with those ram place like this......
may I ask you why your order a mini-itx board for use with 6 hd ?, what kind of case are you using ?
