Old February 7, 2011, 03:43 PM
Hey Bobtat - the case I am using is
Lian Li PC-Q08B Black Aluminum ITX Cube SFF Case 1X5.25 6X3.5INT USB3.0 Audio No PS
Old February 25, 2011, 11:18 AM
Hi, when attaching the internal connections for the front panel, does the polarity of the connectors matter? I cant seem to see anywhere on the connectors where the polarity is marked, unless there is a colour wire convention I am not aware of - each of the paired wires has a white and another colour. If it does matter, is the white pos or neg?
Thanks again in anticipation.
Chris
Old February 25, 2011, 11:44 AM
Chris
Yup it does!
Otherwise nothing will work properly.
Old February 25, 2011, 11:47 AM
Chris
No it doesn't matter
Old February 25, 2011, 12:04 PM
SugarJ's Avatar
The colored wires should be positive, with white being the negative. Polarity does not matter on Power and Reset connections, but any HDD or LED connections must be hooked up correctly or the light won't work.
Old February 25, 2011, 12:05 PM
As myself and SugarJ said.. it does matter. Polarity matters with LEDs in computer cases.
Old February 26, 2011, 07:30 AM
Awesome, thanks!
Old February 26, 2011, 02:54 PM
Great, so my system powers up and goes through the post, but while I am setting the system time, it powers itself down for some reason. If I power it up again, it starts up quite willingly but then it powers itself down again after a few minutes. Does anyone know what could be the cause of this?
Thanks!
Chris
  #19 (permalink)
Old February 26, 2011, 03:02 PM
perhaps its warming up to the point of thermal shutdown?
or not all power plugs are properly secured?
could be a short too, but that wouldnt explain the powering up.
  #20 (permalink)
Old February 26, 2011, 03:12 PM
3.0charlie's Avatar
Did you install the heatsink / fan assembly?
Hydro-Quebec is salivating...
Tags
connecting optical drive , home server , new build , zotac motherboard
[WTB] Zotac mini-itx board 3.0charlie Buy/Sell & Trade 2 January 1, 2011 07:58 AM
The Overclocked Performance of the mini-ITX H55 MB form ECS H55H-I windwithme Member Reviews 9 May 18, 2010 09:06 PM
ZOTAC Unleashes Latest LGA775 Mini-ITX Platform FiXT Press Releases & Tech News 13 December 9, 2009 11:34 AM
Zotac Releases New ION ITX-F Mini ITX Solution FiXT Press Releases & Tech News 6 October 1, 2009 05:47 AM
