-   -   Buying this Weekend. Help please. (http://www.hardwarecanucks.com/forum/new-builds/40518-buying-weekend-help-please.html)
jaspap February 4, 2011 07:16 PM
After building a pc for my buddy, now another one wants one. He will mostly be using it for WOW, SC2 and probably other games as well, also Light homework. This is what I came up with, what do you think? Please any info would be helpful, thanks. I have to get all the parts from Memoryexpress.com, please keep that in mind, thanks.
http://www.memoryexpress.com/Images/...&ImgSize=Smallhttp://www.memoryexpress.com/Images/...ts/list_sh.png Antec Dark Fleet DF-30 Case ILC: 761345152303 SKU: MX29416
$94.99
$94.99 http://www.memoryexpress.com/Images/...l_help_btn.gifAbout IPR
http://www.memoryexpress.com/images/.../DropArrow.gifNone, I do not want In-Store Product Replacement
2 Year IPR Replacement Plan ($8.99)
3 Year IPR Replacement Plan ($10.99)
4 Year IPR Replacement Plan ($15.99)
http://www.memoryexpress.com/Images/...&ImgSize=Smallhttp://www.memoryexpress.com/Images/...ts/list_sh.png Patriot Extreme Performance Sector 5 G Series DDR3 4GB (2 x 2GB) PC3-10666 Enhanced Latency Kit ILC: 879699009140 SKU: MX29795
$69.99
$69.99 http://www.memoryexpress.com/Images/...l_help_btn.gifAbout IPR
2 Year IPR Replacement Plan ($4.99)
3 Year IPR Replacement Plan ($6.99)
4 Year IPR Replacement Plan ($8.99)
http://www.memoryexpress.com/Images/...&ImgSize=Smallhttp://www.memoryexpress.com/Images/...ts/list_sh.png Hitachi 1TB Deskstar 7K1000.C SATA II Internal Drive Kit w/ 32MB Cache ILC: 705487185287 SKU: MX29731
$69.99
2 Year IPR Replacement Plan ($5.99)
4 Year IPR Replacement Plan ($9.99)
http://www.memoryexpress.com/Images/...&ImgSize=Smallhttp://www.memoryexpress.com/Images/...ts/list_sh.png Asus 24x DVD-RW Drive, SATA w/ LightScribe, Black, OEM ILC: 610839415311 SKU: MX30853
$29.99
$29.99 http://www.memoryexpress.com/Images/...l_help_btn.gifAbout IPR
2 Year IPR Replacement Plan ($2.99)
3 Year IPR Replacement Plan ($2.99)
4 Year IPR Replacement Plan ($3.99)
http://www.memoryexpress.com/Images/...&ImgSize=Smallhttp://www.memoryexpress.com/Images/...ts/list_sh.png Sapphire Radeon HD 6950 2GB GDDR5 PCI-E w/ Dual DVI, HDMI, Dual DisplayPort ILC: 840777051450 SKU: MX31490
$299.99
$299.99 http://www.memoryexpress.com/Images/...l_help_btn.gifAbout IPR
2 Year IPR Replacement Plan ($32.99)
3 Year IPR Replacement Plan ($49.99)
4 Year IPR Replacement Plan ($59.99)
http://www.memoryexpress.com/Images/...&ImgSize=Smallhttp://www.memoryexpress.com/Images/...ts/list_sh.png Corsair TX 750W Power Supply w/ 140mm Fan ILC: 843591000406 SKU: MX18779
$94.99
2 Year IPR Replacement Plan ($13.99)
3 Year IPR Replacement Plan ($20.99)
4 Year IPR Replacement Plan ($24.99)
http://www.memoryexpress.com/Images/...&ImgSize=Smallhttp://www.memoryexpress.com/Images/...ts/list_sh.png Samsung SyncMaster E2320X 23in Widescreen LCD, Black ILC: 729507813189 SKU: MX28585
$164.99
$164.99 http://www.memoryexpress.com/Images/...l_help_btn.gifAbout IPR
2 Year IPR Replacement Plan ($18.99)
3 Year IPR Replacement Plan ($27.99)
4 Year IPR Replacement Plan ($33.99)
http://www.memoryexpress.com/Images/...&ImgSize=Smallhttp://www.memoryexpress.com/Images/...ts/list_sh.png Microsoft Windows 7 Home Premium x64 (64-bit) DVD - OEM ILC: GFC-00599 SKU: MX25758
$99.99
$99.99
http://www.memoryexpress.com/Images/...&ImgSize=Smallhttp://www.memoryexpress.com/Images/...ts/list_sh.png P7H55-M Pro Bundle w/ Intel Core i5 Processor 760
$297.98
$297.98 http://www.memoryexpress.com/Images/...t/expanded.gif
1 x Intel - Core™ i5 Processor 760 2.8GHz w/ 8MB Cache $199.99 1 x Asus - P7H55-M PRO w/ DualDDR3 1600, 7.1 Audio, Gigabit Lan, PCI-E x16, HDMI $97.99 1 x - P7H55-MPro+Ci5760 $20 IR $0.00
Sub Total $1,222.90
_dangtx_ February 4, 2011 07:23 PM
how about a cm 922?
you can get cheaper/more ram for that price.
get one black or f3 if in stock, maybe a 2tb for storage? but that can come later
expensive rw, you should find cheaper
good psu, older design though.
maybe something newer, like hx? gonna be more expensive though.
i wouldnt get a quad in 1156 form, a cheap duallie like 530/540 and clock it well? yeah.
or wait till the 1155 fiasco is solved, or find a board elsewhere and get the 2500k.
Gigabyte GA-P55A-UD3 w/ Dual DDR3 2200, 7.1 Audio, Gigabit Lan, PCI-E, CrossFireX at Memory Express Computers
Gigabyte GA-P55M-UD4 w/ Dual DDR3 2200, 7.1 Audio, Gigabit Lan, 1394, PCI-E, CrossFireX / SLI at Memory Express Computers
Gigabyte H55M-UD2H w/ Intel Core i3 Processor 530 at Memory Express Computers
Intel Core
MSI P55-GD65 w/ Dual DDR3 1333, 7.1 Audio, Dual Gigabit Lan, 1394, PCI-E, CrossFireX / SLI at Memory Express Computers
jaspap February 4, 2011 07:54 PM
How hard would it be to overclock an i3 540? Do I need to buy some software or anything or can I just do it in the bios of that Gigabyte motherboard you showed? Thanks.
_dangtx_ February 4, 2011 08:15 PM
really easy. if you go for the 'better' boards like ud3/4 or the msi gd65 itll be a breeze.
i repeat myself lol, but 1156 is for i3' cpus on a budget. and once clocked itll be a little monster.
sky has posted a review last year i believe...
http://www.hardwarecanucks.com/forum...review-14.html
you need more? 1155, andyou find a board.
no inbetween. unles you find a super cheap i5 760 but even then, bang per buck the i3's do a killing
i always tell people, take it easy now if you dont need all the cpu hp in the world, investing
250 dollars in board + cpu vs more means down the road you can yank it out with less remorse lol
spikexp February 4, 2011 08:24 PM
You can have a Phenom II x4 955 + gigabyte 870a-ud3 for 230$.
Delavan February 5, 2011 12:47 PM
IMHO, this is the most boring time in computer history for the past few years...freakin Intel screw-up...
AMD Bulldozer not out yet...
Anyway, I'd take the GTX570 over the HD6950 ANY DAY...570 is quieter and equivalent to HD6970....
MSI GTX570 for $299 on sale at NCIX....(3 years warranty, RMA in CANADA), and a $20 MIR on top of that...I think it comes with the game JUST CAUSE 2...and MAFIA II
N570GTX-M2D12D5
_dangtx_ February 5, 2011 12:50 PM
and 6950 for around 30 lower :p
