What we're trying to tell you is that you have listed some obsolete parts which should be replaced completely, such as the Ge210. As Ilya has suggested, the Sandybridge i5-2500 processor has a built in integrated graphics support that meets
all your needs, and is supported on the H67 motherboard. Its performance is very comparable to the Ge210, from results tested
here.
For your build, I swapped out the RAM..just brand and experience preference. Same with the power supply..I went for what was cheaper yet same/better quality. And out of curiosity, what are CB_0001W
POWER ADAPTER and EYD-OOO23-SINGLE
USB?
Your build should be something like this
$43
RAM
$94
OS
$80
HDD
$92
Mobo
$38
Case
$35
PSU (this can sometimes be found for <$20 with a MIR)
$210
CPU
$100
ODD
$<75 Peripherals (wireless card/fan)
$50 assembly fee
That totals to ~$800, with room to toss in a sweet SSD.
