Old January 23, 2011, 07:51 PM
Default 24 pin power connector
this is my second build the first one was in 96 my problem is with the 24 pin connector on the motherboard, it post with 20 pin + the 4 pin for the cpu but it with the 24 pin thers no post no fans it's all dead even if i add the cpu 4 pin. I'm at a lose on how to get the 24 pin to work.
build info
motherboard asus m4a78t-e
power supply cm gx 750w
amd x4 965
cpu cooler hyper 212 plus
Old January 24, 2011, 06:58 AM
are you sure you're inserting all the connectors with the correct orientation?
Old January 24, 2011, 09:28 AM
Make sure you flick your power supply on (there's a switch at the back).
Also, try the PSU in your previous desktop so we can rule out whether or not it's a dud.
Old January 24, 2011, 11:14 AM
i'm getting 12v on the 2 yellow wires on the p3 connector for the cpu for a total 24v and on the P1 mo connecter the last 4 has 12v yeallow 3.3v orange 5v purple for a total of 20.3v, dont i need 3.7v on it to make the 24v for the cpu.
Old January 24, 2011, 01:02 PM
??? those voltages don't sum.
The extra 4 pin for a motherboard give you another +5, +3.3, +12V, and GND to allow you to have more CURRENT, not voltage going to the motherboard. The CPU is the same thing, where +12V are placed in PARALLEL so you have have more current going to the CPU, but still at +12V (to allow the motherboard's VRMs to send the ~1.2-1.3V or whatever the CPU actually wants).
Old January 26, 2011, 09:35 AM
Ctech's Avatar
Restricted Poster
Where's the RAM???
8 Pin 12V ATX Connector element291 Power Supplies 6 August 24, 2009 08:52 PM
[WTB] 2 PIN CONNECTOR FOR INVERTER BOX sinticfury Buy/Sell & Trade 10 June 27, 2009 11:08 AM
4 pin molex connector Phobia Off Topic 9 June 2, 2009 12:59 AM
Sleeving 24-pin ATX connector LC0g Guides & How-to's 19 May 19, 2009 06:18 AM
8-pin PCIe connector Dave510 Troubleshooting 13 April 24, 2009 07:54 PM
