Old January 23, 2011, 07:59 AM
fyshawk's Avatar
Default H50 CPU Cooler vs Coolmaster V8 Advice please
1) What will you be doing with this ------ Gaming -and Overclocking it
2) Parts already being picked up
3) Where do you live----Oshawa Ontario Canada
4) Parts already being picked up
5) Nothing reused
6) Will you be overclocking----Yes
7) What size monitor do you have 24 inch will be getting another one to match
8) Within the next two days
9) What features do you need in a motherboard --Raid
10) Do you already have a legit and reusable/transferable OS key/license yes Windows 7 Pro 64bit
ok finally got everything for build here is what i have
Intel I7 950
Coolmaster V8 Heatsink
Asus Rampage III Formula Rog X58
Ocz Vertex2 SSD 120gb
12 gig Corsair Vengence 1600 3x4
XFX Radeon 6870
Corsair 800D case
750AX Corsair PSU
3 120 Enermax Apollish Case fans for Top of case
Now I will be doing some over clocking with this setup and my Question is
Should I exchange the Coolmaster V8 for the Corsair H50 Cooler and if i did has anyone here used it on their systems and does it have to be set up to pull air in from rear of case
please give me your opinions thank you
as i have everything ready to go just deciding on switching coolers
Intel I7 4770K
Asrock Z87 Extreme11/ac Motherboard /32 Gigs Mushkin Memory
2 x 120 Gig Mushkin SATA III SSD /1 x 240 Gig SSD/1 x 1TB Gig
Radeon 7970 3 Gig Video Card
/Corsair 800D case
1x Benq 27 Inch Gaming Monitor
Old January 23, 2011, 08:35 AM
fishingfanatic's Avatar
Smile Cooling
In my experience, which isn't vast, but I'm always trying to improve cooling to be able to do more, I've had a # of coolers. The V6GT was way too loud for me! My best results actually came from the Ultra Chilltec Thermal
Electric cooler. Cpu @ 4.0 and temps idling around 27 C.
The 5.25" panel temperature reading doesn't match real temps, so if you get one, do put on the alarm and don't trust the readings!
Have yet to try the V8, but the V6 actually performs better if I remember correctly. Recently purchased the V10, but haven't had a chance to put it thru its paces.
Good luck and let us know what you finally decide on,plz.
Old January 23, 2011, 09:23 AM
fyshawk's Avatar
I have the V8 on my current setup in my sig and my temps right now are
17c 18c 17c 18c pretty well on idle but in gaming they are still low
as i have the thermaltake armour with 3 120s in front 1 120s in rear
and 1 x 92 in rear and top
also the 120 on the cpu in the V8
Intel I7 4770K
/Corsair 800D case
Advice on CPU cooler rfielder CPU's and Motherboards 7 February 5, 2010 08:50 AM
Corsair Hydro H50 CPU cooler FtGF Water Cooling 54 July 24, 2009 04:34 AM
