600T vs. Phantom I have came down to deciding between these two cases. The only difference I can tell is that the 600T is not as strong in asthetics but its build quality is excellent. On the other hand, Phantom lacks build quality but looks amazing. I am going with a Noctua D14...what do you think is a better case for air cooling and in overall? |
From what I have read the phantom does have good build quality, and the highest thickness of ABS wherever there is plastic. So that shouldn't be a problem with either case choice. That being said, originally I was going to opt and get myself a Phantom, however NZXT decided that once again it would make a propritery fan for its case. No other 200mm fans will fit except NZXT's.... They actually have a 192mm offset. Which means if you want to add a second top fan or fill the side 200mm Fan you will have to buy it from NZXT or someone that carries their fan specifically. Much like why I didn't like the Panzer Box , NZXT disappointed me for this and this alone. Otherwise, if you can get past that the Phantom does have the greater cooling potential IMO. ST |
Does the stock phantom come with any LED lighting inside? (not the turn on/off light, knobs) but the fans? |
The Top 200mm fan is the only one I believe that is LED lit. ST |
