Old January 15, 2011, 11:57 AM
Mr. Toda's Avatar
Default New build (Help pick out some parts)
PLEASE when POST threads asking for input on system builds tell us...
Mostly gaming, maybe try F@H
$1500-1800 (tower)
Canada NCIX
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
None really
Already bought a 800D, 1T black HD, Sam DVD drive
Yes
Yes middle of the range
Want to order this weekend
9. What resolution do you use?
Need a new monitor1920x1080
CPU Cooler:
Open to options
NCIX.com - Buy Noctua NH-C12P SE14 LGA775/1156/1366/AM3 I7/I5/PHENOM Heatpipe Cooler W/ NF-P14 140MM Fan - NH-C12P SE14 In Canada.
CPU
2500K or 2600K Still can't pick one. I know for gaming I won't notice anything.
Motherboard: I want to be able to have a sound card, wireless N card, and duel GPU if possible.
NCIX.com - Buy ASUS P8P67 Pro ATX P67 LGA1155 DDR3 3PCI-E16 2PCI-E1 2PCI SATA3 USB3.0 Sound GBLAN Motherboard - P8P67 PRO In Canada.
Ram: Need help picking Ram, all I know is I want 2x4GB
NCIX.com - Buy Mushkin Enhanced Silverline Stiletto 8GB 2X4GB PC3-10666 DDR3-1333 9-9-9-24 Dual Channel Memory Kit - 996770 In Canada.
or
NCIX.com - Buy Mushkin Enhanced Blackline Frostbyte 8GB 2X4GB PC3-12800 DDR3-1600 C9-9-9-24 Dual Channel Memory Kit - 996776 In Canada.
or
NCIX.com - Buy G.SKILL Ripjaws X F3-10666CL9D-8GBXL 8GB 2X4GB DDR3-1333 CL9-9-9-24 Memory - F3-10666CL9D-8GBXL In Canada.
PSU: Some people say the cables are too short, I would have got the XFX 850 but NCIX is sold out right now. I want an 850W or higher, I am fine with over kill
NCIX.com - Buy Corsair Professional Series Gold AX850 CMPSU-850AX 850W ATX Fully Modular 80PLUS Gold Power Supply - CMPSU-850AX A In Canada.
OS
NCIX.com - Buy Microsoft Windows 7 Home Premium Edition 64BIT DVD OEM - GFC-00599 In Canada.
SSD
NCIX.com - Buy OCZ Vertex 2 Extended Sandforce 60GB 2.5IN SATA2 Solid State Disk Flash Drive SSD - OCZSSD2-2VTXE60G In Canada.
GPU:
Thinking about one GTX 570
NCIX.com - Buy EVGA GeForce GTX 570 Fermi 732MHZ 1280MB GDDR5 2XDVI Mini-HDMI PCI-E Video Card - 012-P3-1570-AR In Canada.
Sound Card:
I use PC350 for almost all my sound (what do you think of this sound card for PC350's)
NCIX.com - Buy ASUS Xonar DX 7.1 Channel PCI-E Sound Card 24BIT Dolby Digital 116DB SNR W/ Low Profile Bracket - XONAR DX In Canada.
Items I own already
Case: going to air cool it, and at $199.99 I bought it because I just wanted it.
NCIX.com - Buy Corsair Obsidian Series 800D Full Tower Case EATX 5X5.25 4X3.5 Hotswappable 2X3.5INT No PS USB 1394 - CC800DW In Canada.
HDD
NCIX.com - Buy Western Digital Caviar Black 1TB SATA3 6GB/S 7200RPM 64MB Cache 3.5IN Dual Proc Hard Drive OEM - WD1002FAEX In Canada.
DVD drive
NCIX.com - Buy Samsung SH-S223C 22X DVD Writer SATA Black OEM - SH-S223C/BEBE-OEM In Canada.
Total price (no price check yet) 2600K with Mushkin frostbyte ram 1,608.09
Still need a Monitor will pick a 24 inch LCD LED
Upgrading from a P4 3.2 GHz X850 XT PE very old but it did its job well.
I am open to any and all options, Normally I wouldn't build my own system but its something I have always wanted to do. So any help making my final build would be great.
Thank you.
Old January 15, 2011, 12:42 PM
looks like you did your homework. 2600k if you want to spank some folding numbers :)
maybe go with shorter ram sticks so you can fit anything above? :)
Old January 15, 2011, 01:52 PM
Mr. Toda's Avatar
Could you give me an option since I have know idea about ram. Are you saying my heatsink wont clear the ram?
Old January 15, 2011, 01:55 PM
the mushkin stiletto's are short. so go with them. i have some tall ram and love them for the cooling potential, but most of my coolers,tower coolers not downdraft ones, cant fit.
ripjaws and the like are a bit taller. that noctua will clear most sticks though
Old January 15, 2011, 02:09 PM
ZZLEE's Avatar
Blacklines are nice and low not likely to have problems with them.
I would go blackline over the silvers.
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old January 15, 2011, 02:15 PM
I'd avoid the Samsung SH-223 optical drive, they're pretty hit and miss for burn quality. You'd be better off grabbing a Samsung SH-243D BEBE and pricematching it to $16.
Old January 15, 2011, 02:26 PM
Mr. Toda's Avatar
On a side note, if I went with the ASUS P8P67 Deluxe could I make the 3.5" USB 3.0 header fit into one of my 800D 5.25" drive bays?
Old January 15, 2011, 04:23 PM
ZZLEE's Avatar
Newegg.ca - BYTECC Bracket-535 5.25" Metal Tray for 2.5", 3.5" HDD/Slim DVD
try this
Old January 16, 2011, 06:16 AM
I have a question about this build; would installing a PCI-E sound card, or any PCI-E device for that matter, on the third, fourth etc. slot reduce lanes from 8 to 4 for the first two, which will most likely be used for 8x8 dual GPUs?
Old January 16, 2011, 11:41 AM
Mr. Toda's Avatar
About to order and a few changes, one last look over please.
CPU: $319.99
NCIX.com - Buy Intel Core i7 2600K Quad Core Unlocked Hyperthreading Processor LGA1155 3.4GHZ Sandy Bridge 8MB - BX80623I72600K In Canada.
Mobo $179.99
Ram 99.99 went with corsair
NCIX.com - Buy Corsair CMZ8GX3M2A1600C9 Vengeance 8GB 2X4GB DDR3-1600 CL9-9-9-24 Dual Channel Memory Kit - CMZ8GX3M2A1600C9 In Canada.
GPU $319.99 went with Zotac
NCIX.com - Buy Zotac GeForce GTX 570 Fermi 732MHZ 1280MB 3.8GHZ GDDR5 2XDVI Mini-HDMI PCI-E DirectX 11 Video Card - ZT-50201-10P In Canada.
Heatsink went with corsair H70 $74.99 after MIR
NCIX.com - Buy Corsair Cooling Hydro Series H70 High Performance CPU Cooler System LGA775 1366 1156 AM2 AM3 - CWCH70 In Canada.
PSU $185.54 after PC
SSD $94.99 after MIR
OS $93.79 after PC (hope they take it)
Win 7 64 bit
Monitor $396.97 after PC (saved $3, one site had it for like $370 but had no stock and had a cash deal) also bought the zero dead pixel for $20
NCIX.com - Buy BenQ XL2410T 23.6IN Widescreen 120HZ LCD Monitor LED 1920X1080 2MS DVI HDMI HAS Pivot 3D Ready - XL2410T In Canada.
Fans $15.98 each (x3) for top of my 800D
NCIX.com - Buy Scythe Gentle Typhoon 120MM Case Fan 1450RPM 21DB 45.9CFM - D1225C12B4AP-14 In Canada.
Again I already own a DVD drive, HDD 1T black, 800D.
I am going to hold off on the sound card for now and get one with a built in amp.
One last question will price match hold my hole order up if one item is rejected? and will they honour the sale prices of the other items if my order is held up past the sale date and or MIR? (Sorry for the questions since I have never used price match before)
If someone could give me one last look over that would be great before I order. Total $1896.86 before tax and shipping
Thank you.
Pick apart my proposed HTPC build VanceFox HTPC Systems & Software 17 November 8, 2010 12:00 AM
Help req on new build Parts seb New Builds 6 November 25, 2009 07:38 PM
Help me pick my parts! BrokenHalo83 Water Cooling 21 May 10, 2009 06:31 PM
Not really a new build . . just new parts Wein13 New Builds 7 October 4, 2008 09:15 AM
Help me pick parts! encorp Water Cooling 12 September 15, 2008 10:56 PM
