Old December 28, 2010, 06:50 PM
Mark's Avatar
Question Question about air cooling
I have my system ready to go which includes the following items:
Sapphire 6970 2g
Asus P6X58D premium
i7 970
3x4GB of Gskill Ripjaw Series 1600mhz
Antec TPQ-1000watt
The system will be installed in my custom built TJ9 Silverstone case that has plenty of fans. I don't think I want to water cool the system anymore and will have all of it for sale soon enough so I'm looking at air cooling. ( I don't think a dual rad will be worth the trouble of cooling the I7 970)
Is the Thermalright MUX-120 better then the hsf that Intel provides?
Factory hsf:
I will overclock and would like to hit close to 4Ghz.
BTW, would also like your opinion on the videocard.
CHEERS
Old December 28, 2010, 08:27 PM
jcmaz's Avatar
Yes it should be better than stock. I don't think there are coolers for the 6970 yet...
-Plato
Old December 28, 2010, 09:22 PM
BootlegUsher's Avatar
That Intel stock HSF looks pretty decent. Those are nice high res pictures by the way.
Old December 28, 2010, 10:08 PM
Mark's Avatar
I'm not going to change the hsf for the videocard. Never notice a significant difference to merit overclocking the gpu...just the cpu in this case.
Those pictures were taken from the net.
CHEERS
Old December 28, 2010, 10:17 PM
martin_metal_88's Avatar
I would sya, test it with the stock HSF and if you think it's not enough jump to something bigger like the venomus-X? Even if the stock HSF for the 970 and 980X perform pretty good but the leader cooler are still a bit better.
Old December 28, 2010, 11:37 PM
for that stock cooler im not convinced itll make,rather a lot, much difference. now if were talking top of the line noctua or thermalright? sure, well worth it IF you oc ;) or if you want it to be more quiet.
Best Air Cooling For A 4890? Caldezar Air Cooling 5 November 23, 2009 03:08 PM
Now THIS is what I call air cooling! kruzn4evr Air Cooling 30 June 27, 2009 07:18 PM
Air Cooling your Chipset Soultribunal Air Cooling 10 January 28, 2009 04:32 PM
Will air cooling do the trick? blogz101 Air Cooling 3 July 10, 2008 06:10 PM
What is better?Air Cooling blogz101 Air Cooling 13 July 9, 2008 03:13 PM
