Old December 23, 2010, 09:22 AM
Trial Member
Default First Time Ever Building
Computer gaming and programming
1250-1500
Canada
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
None, just prefer quality products
None
Yes. I've been lurking the forums for a while now.
I have never Oc'd but would be willing to if I had a reason and a good tutorial
ASAP
9. What resolution do you use?
1920*1080
Would prefer to build a system that can have some staying power, and be able to play the new Diablo when it comes out at a high level. If I have to spend a bit more to do it I would.
Old December 24, 2010, 07:53 AM
You can go either AMD or Intel... Intel will be releasing Sandy Bridge on Jan 9th and it's very promising. As for Video card a 6970 or 570 from Nvidia can handle pretty much anything at 1080p.
4Gb or ram is perfect, if you come around a deal for 8 why not...
It's about 1149$+tx for :
I5 760
750 OCZ PSU
P55A MSI Board
1TB WD Black HDD
GTX 570 Video Card
CM HAF912 Case
4GB of Ram
LG DVD Writer
Copy of Windows 7 Home Premium
If you need a monitor and KeyB+Mouse it would be extras..
Old December 24, 2010, 09:48 AM
Keltron 3030's Avatar
^^^Looks good, but get a different PSU. go corsair, seasonic or even (dont flame on me) the new thermaltake line. you want a good quality one to handle your rig. And go with 750-850 Watts with a good effeciency (silver or gold). This way you can go SLI with 2x 570 and not have any worries
As for RAM, look into GSkill. good RAM at a good price!
The HAF912 is more of a budget case. Also you should choose your case, as your gonna have to look at it for a long time :P
FFFFFFFUUUUUUUUUUUU-
Old December 25, 2010, 05:37 PM
The ram in the kit in G.Skill ;) that's what a got
I only suggested a 912 because it 56$, add 50$ for a more elaborate case..
PSU, yeah it's also a very random subjet.. i've been using Antec all my life without any problems with them, altought there mostly always overpriced. But they, this one was on sale recently that's why i included it in the price ;)
Old December 25, 2010, 06:41 PM
Blu's Avatar
Blu Blu is offline
I used to have a OCZ psu which ran very well for a few years until I built a whole new pc. Now I got a corsair 750watt and it runs really well and am going to try out a seasonic for my htpc build. So I would suggest anyone of the three, I know alot of people will say 'eww ocz' but it got the job done and powered everything I needed well my only complaint on it was one 4 pin molex line had very little power, I plugged two fans into it and they ran as slow as a snail, if I only plugged one into it the fan was much faster so I ended up having to swap it for the second one.
Old December 27, 2010, 06:49 PM
I would say that Corsair and SeaSonic are at the top right now in terms of Power Supply reliability. OCZ seems to be either hit or miss. Antec is not a bad choice, either.
Old December 27, 2010, 07:08 PM
not really. ocz is ok, just not great. series II are better than the first ones, making them decent. i wouldnt be afraid to build a pc with an ocz psu, never was. id be a tad concerned about the scopes if i were to run it full bore to the top vs a seasonic unit :)
Old December 28, 2010, 12:03 AM
XFX black edition are nice budget PSUs. Enermax are high-end and compete with Corsair AX series.
Building Again fyshawk New Builds 0 May 9, 2010 06:00 PM
Building a new computer for the first time! Anant New Builds 43 April 30, 2010 01:45 PM
[WTB] Building time of the year : Core i7 Rig Minimal DJ Buy/Sell & Trade 5 September 3, 2009 09:12 AM
[WTB] blue ray movies ( will be updated with more from time to time) kyle_L Buy/Sell & Trade 3 September 2, 2009 04:20 AM
Building Phobia Off Topic 9 September 21, 2008 12:29 PM
