Old December 18, 2010, 11:30 AM
Question Upgrading a few parts in my rig, would appreciate help please.
Hello folks, first time posting here.
So I think my rig is getting a bit long in the tooth and it's Christmas so I can ask for at least one upgrade .
Here are the parts in my current rig (for compatibility reference):
- CPU: E8400 @ 3ghz
- Mobo: nForce 780i (link)
- GPU: 8800GTX (link)
- Ram: 4GB DDR2 1066 (link)
Ok, so I am thinking about upgrading the GPU to a GTX 460. Good choice?
I also need to upgrade my ram, anyone have any suggestions? I was looking at this, but I really have no idea about whether or not it is compatible with my mobo, or if it's even worth the money to upgrade to that specific kit.
*EDIT* I just found out that my mobo does not support DDR3 ram. Lamesauce .
I want to overclock my CPU as well...I currently have a copper Zalman heatsink w/ fan on it, not sure of exact model name; but it's quite large heh. I have never overclocked a CPU before, so if you have any advice or info on that I am all ears.
Here's a pic of the heatsink just in case (note that there is a fan in between those copper blades)
Any help or suggestions would be appreciated, thank you.
p.s. If I upgrade the GPU, ram, and overclock the CPU, how much longer do you think this rig will last me?
-Gaming
-Bang for the buck. Maybe $80 tops as far as ram goes. $180 for GPU.
-USA
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
-No preference, although since I had an nVidia card before I don't mind going with them again.
-OC, yes. Need help with it though.
-Asap.
9. What resolution do you use?
-1920x1080
Old December 18, 2010, 03:37 PM
Slik's Avatar
If I were you, I would wait for a 500 series Video card. They out shine the 400 series in every way.
EVGA DG 87 -i7 5930k @ 4.4ghz. Liquid cooled-4x4gb G Skill Trident X DDR3@ 2400mhz- EVGA x 2 1080 Ti Black SLI - Soundblaster X7 Sound Card- LG 34" Monitor-ATH AG1X Headphones-Butt Kicker Gamer-TrackIR 5
Old December 18, 2010, 05:04 PM
But I only have a limited budget (around $180) and those cards would be out of my price range anyways...right?
Old December 18, 2010, 08:27 PM
If you don't mind MIR, the EVGA GTX460 you linked is certainly a very good choice. If not, your other option would be a 6850. Save your money on the RAM. You should be able to hold out on replacing your computer for 2 years or more.
Old December 18, 2010, 08:44 PM
watch out for a super special on a 6850 unless you need cuda :)
your setup is ok. for the time being. oc wise, give it a go fsb wise, drop your ram speed.
Old December 19, 2010, 08:42 AM
Thanks for the replies guys.
Think I will be able to overclock safely with this CPU cooler?
Old December 19, 2010, 09:22 AM
that cpu will do fairly well with stock. or get a cooler master 212+ :)
now, that cooler you linked is nice, but bang per buck? meh
Old December 19, 2010, 10:08 AM
*shrug* I bought it two years ago. I knew less then than I do now.
Old December 21, 2010, 05:15 PM
I would not go with a GTX 460. A GTS 450 would be much better for your system, considering your CPU is only a dual-core. If you can wait, AMD will be releasing some lower-end GPU's early in 2011, so keep an eye out for those.
Old December 21, 2010, 05:59 PM
I have a Radeon 4870 which is about the same or slightly worse than a GTS 450 in performance with an even weaker gaming CPU (the Phenom 9950 at 2.7 GHz which is easily beaten by Intel C2D in single threaded gaming clock for clock).
At 1650x1080 I am GPU bottlenecked in Crysis and S.T.A.L.K.E.R. Call of Pripyat DX10, so the OP will be even more limited at 1920x1080, using a GTS 450.
[FS] Parts of rig, Grado Phones, +others Dar_T Buy/Sell & Trade 2 October 19, 2009 10:27 AM
Upgrading my gaming rig Mustkunstn1k New Builds 12 July 6, 2009 07:32 AM
Upgrading a rig for ~500$ Mustkunstn1k New Builds 16 February 9, 2009 10:28 AM
Upgrading a gaming rig Evylldemon New Builds 7 November 10, 2008 11:09 AM
Future proofing and upgrading rig, Free Beer Inside! D4ng3r New Builds 20 October 23, 2008 08:01 PM
