THIS RIG IS REAL!
Thanks to everyone for their advice. I've purchased the rig from NCIX. Just awaiting its completion.
Hello all! :)
My previous experience at building a computer is very limited. (taking two old computers and switching components so one has the better of the two)
I have considered if a store in my area would build it for me...but I think I can do this myself. My big concerns are putting the cpu on the mobo, protecting everything from static electricity, and any issue I have to go into the bios for. And i've never connected everything to a mobo from scratch. A few mysteries for me, but I think I can do it, and i've got local friends who could help if needed.
I've spent a huge amount of time surfing the net the past 3 weeks, looking at building a gaming rig for an eyefinity 3 monitor setup.
I'm not really asking you to build something for me...seeing i've done a lot of the research already and am fairly confident that it is okay.
I'm really asking for someone to confirm that the list i'm providing below will not have compatibility issues...and if something IS incompatible, any suggestions would be very much appreciated.
My biggest hassle was finding the 4x 4GB of RAM I want. The mobo and RAM manufacturer sites have their lists...but there's not much 4GB sticks out there.
And I did go out of my way to make it look nice. I will add some lighting for it as well.
1. The PC will be used for simulation racing games, photo editing (Photoshop 7), 3D editing (Blender)...and perhaps some modest video editing with 1GB files.
2. My budget is inbetween $3500-5000.
3. I'm in Canada and buying most components from Canada. But may be looking at a few things from the U.S. (e.g lighting mods)
4. The machine has to be an AMD cpu and ATI video card.
5. All parts are new. See list below... (although I will be attaching a wheel, pedals, scanner, 3 external 1TB drives, mouse and keyboard, USB headphones)...printers are evil. lol
6. Haven't actually looked at "build" threads...but looked at tons of reviews for products, and online stores.
7. Overclocking isn't a big concern for me...but I did expect to try it. So...yes. :)
8. I plan to build it within the next two months. The sooner the better. I would like to start ordering components immediately, but this was the last thing to do before buying...get someone else's opinion.
9. I'm expecting to run 5760x1080. With 3 monitors using the eyefinity feature.
I just did a quick search at Newegg.ca and found most of what I want. Of course, the RAM is out of stock. I'm being picky about the RAM...I want this to look cool...so blue and gold colour is not what I want.
And
i've chosen 2000 RAM...and I know I could use 1333 or 1600...I may go down for a lower price. I suppose i'm not getting much of a performance difference with 16GB of 2000 instead of 16GB of 1600...but I really don't know much about that. The 2000 is mighty expensive.
I'm still uncertain about what cpu fan to use. (3 listed below)
I
may buy a 3 fan radiator for the top of the Obsidian case later on. I don't think I need it...and don't want the computer to be too loud if I can help it.
I will probably
buy a second Asus Matrix 5870P card later...using crossfire. (when their price gets lower) Either that...or replace it with the upcoming 6990 when it goes under $600.
I'm still not certain of the monitors I will use...other than they will all be the same model and size, 2ms, can do 1920x1080 and there will be 3 of them.
============THE LIST OF COMPONENTS FOR MY GAMING PC============== -Please tell me if something doesn't make sense here...or will not work together with the other components
AMD Phenom II X6 1090T Black Edition Thuban 3.2GHz Socket AM3 125W Six-Core Desktop Processor HDT90ZFBGRBOX
ASUS Crosshair IV Extreme AM3 AMD 890FX SATA 6Gb/s USB 3.0 AMD Motherboard
[2x] G.SKILL Flare Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 2000 (PC3 16000) Desktop Memory Model F3-
ASUS ROG MATRIX 5870 P/2DIS/2GD5 Radeon HD 5870 Platinum 2GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card
KINGWIN LZG-1000 GOLD 1000W ATX 12V v2.2 / EPS 12V v2.91 SLI Ready CrossFire Ready 80 PLUS GOLD Certified Modular Active PFC Power Supply
Corsair Obsidian Series 800D CC800DW Black Aluminum / Steel ATX Full Tower Computer Case w/window
Western Digital VelociRaptor WD3000HLFS 300GB 10000 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Seagate Barracuda XT ST32000641AS 2TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Microsoft Windows 7 Professional 64-bit 1-Pack for System Builders
--------------------which one?-------------
EVERCOOL HPJ-12025 120mm Ever Lubricate Bearing (Long Life bearing) Transformer 4 Heat Pipe CPU Cooler
ZALMAN CNPS9900ALED 120mm 2 Ball Low-noise Blue LED CPU Cooler
ZALMAN CNPS 9500 AM2 2 Ball CPU Cooling Fan/Heatsink
[3x] Asus VE248H Black 24" Full HD HDMI LED Backlight LCD Monitor w/Speakers
I
don't need the monitors in the speakers. I use headphones...and will be
looking for some great surround sound headphones. But I do have good computer speakers and subwoofer already.
I also have a huge amount of data on
3 external drives using USB 2.0...and will
want some more ports...either on the front using a spare tray...or at the back.
A
fan control system might be nice at the front in a spare tray. The Obsidian has quite a few...not sure if I should get more.
I'll have at least two optical drives. I don't have much use for Blue-ray...but
need two 24x burners.
I like the Razer
keyboard and
mouse.
The above is listed at Newegg.ca as a wishlist build...viewable by the public, but I don't know how to link to it. If you wanted, you could search for the build under its title: "
Eyfinity 3 monitor config".
As an aside...i've already purchased my racing cockpit, wheel, pedals, and shifter.
I've been playing racing games for 10 years. Mostly I play rFactor now. But i've currently got installed TMS,TMU, TDU, CMR4, Most Wanted, and Underground 2.
I'm attaching the Word document I created to keep track of everything i've been looking at. It's quite a mess in some places...but there's a ton of web links to various products, and at the bottom was supposed to be my final choices. That isn't quite complete.
Feel free to use it and share it.
