Old December 2, 2010, 09:24 AM
Default need powersupply help
So I'm building my new computer and i've run into the issue that i need a new power supply will this be able to handle my rig?
NCIX.com - Buy XFX 650W XXX Edition Single Rail Modular ATX Power Supply ATX12V 52A 24PIN 80PLUS Bronze - P1650XCAH9 In Canada.
my set up is as follows
i5 - 760 going to put a h50 on there and over clock it to 4.0ghz
460gtx's SLI'D
8 gigs of corsair XMS3
a 200 mm fan 3x 120mm fan
1x seagate 320gig baracuda
2x seagate 500gig baracudas
2x westerndigital 1tb's
Old December 2, 2010, 09:51 AM
well, give 200 watts for cpu board...add another 25 for fans...another 25 for drives and then add 250-300 for video cards. since that unit puts out quite the numbers on the necessary 12v rail? looking good.
Old December 2, 2010, 11:00 AM
Soultribunal's Avatar
You're more than fine with that unit. I've got a lot more connected than you do on an HX650. Same GFX cards as well.
ST
www.realhardwarereviews.com
Old December 2, 2010, 11:36 AM
I ran almost the exact same setup just AMD Phenom II 965 with a nf980a board for SLI. My tx650 ran it find but got uncomfortably hot. So I swapped out to the xfx 750w(seasonic oem) for some efficiency since I don't like heat.
It will work find but if your OC'd dual gpu folding and cpu folding expect a 650watt to blow hot air like a space heater.
Old December 2, 2010, 05:10 PM
Bond007's Avatar
it will power your system no problem, but you may want a little more headroom just in case.
Desktop: Arc Midi R2, Z77-D3H, 3770@4.1ghz with Zalman Optima Cooler, 4x4gb ram, EVGA GTX 1070 Ti SC, Bitfenix Fury 750w, WD Black 1TB, MX500 500gb
Away from home: Lenovo Legion Y530, 16gb, i7 8750H, GTX1050Ti
Powersupply Question CORE Power Supplies 5 May 25, 2009 12:42 PM
9600gt minimum powersupply kyle_L Video Cards 4 March 6, 2009 12:44 PM
test dead powersupply? CTA Troubleshooting 15 February 16, 2009 09:56 PM
Need a 12V Powersupply Cptn Vortex Power Supplies 8 January 12, 2009 05:48 PM
Small Powersupply Cptn Vortex Cases 5 November 6, 2007 06:02 PM
