Originally Posted by vohiep84 If you do plan to SLI 480's or 580's i'd recommend to get a higher watt psu, that way you won't need to upgrade in the future when you SLI. (My current dilemma)
As for the case, did you consider how you would mount your radiators? internally / externally
Adding a gpu loop is simple but the cost to do it is expensive. :-) |
I already own the corsair 850 AX So I will use it in this build if i upgrade in the future I will change the psu but for a single gpu it should be fine.
Rads will all be mounted internally
2 x 120 on the side door
2 x 120 on the bottom depending on mobo it may even be possible to stack 2 rads here
2 x 120 OR 3 x 120 (not sure yet, 3 x 120 would probably fit with a little modding) may even be able to stack 3 x 120
Im not worried about rad's there's more then enough room. As for dual loops, maybe in the future i will build with a single and I'm not happy with temps I will change to dual loops.
Phill: Do you think there is a huge advantage with the 580? I was hoping to score some 480s cheap because of the new 580...
