Old November 19, 2010, 11:35 AM
Default Help with 3D build
hey guys so i got my parts lined up for a build this xmas.
Then i decided wtf lets do a 3d build. Question is what do i need to change? Need more PSU watts? Need special video card? need monitor and glasses? Thx
Original parts:
COOLER MASTER HAF X RC-942-KKN1 Black Steel/ Plastic ATX Full Tower Computer Case
ASUS Sabertooth X58 LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
2xEVGA 012-P3-1472-AR GeForce GTX 470 (Fermi) SuperClocked 1280MB 320-bit GDDR5 PCI Express 2.0 x16
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC
Intel Core i7-950 Bloomfield 3.06GHz LGA 1366 130W Quad-Core Processor BX80601950
Kingston SSDNow V Series SNV425-S2BD/64GB 2.5" Desktop Bundle 64GB SATA II Internal Solid State Drive (SSD)
G.SKILL PI Series 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-9
Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Logitech G510 Black USB Wired Game Keyboard
COOLER MASTER Intel Core i7 compatible V8 RR-UV8-XBU1-GP 120mm Rifle CPU Cooler
Old November 19, 2010, 12:07 PM
Keltron 3030's Avatar
needs ALOT more PSU. 850 is bare min. and i mean bare min. if you wanna oc, go even higher
FFFFFFFUUUUUUUUUUUU-
Old November 19, 2010, 01:21 PM
ok thx i guess ill get a 1k psu
but any vid card can do 3d as long as you have the monitor and glasses?
Old November 19, 2010, 02:20 PM
Any compatible Nvidia card, the 470's will handle it no problem. But yeah, a 750 WOULD WORK. although you would be loading it near capacity without any OC's which could shorten it's lifespan.
Old November 19, 2010, 05:38 PM
fishingfanatic's Avatar
Smile New Builds
I would consider changing your psu to modular as well. The new AX series from Corsair comes to mind, the 850. Or get the HX1000 which I owned and never had any issues at all.
The SSD I would use 4 my OS would be the Vertex II. I've had the Kingston. Good unit, only rated 7.4 vs 7.9 on Windows rating. Rather subjective rating system though. 980 only rates 7.7 unless oced to 4.0 or better.
Look at the P6X58D-E motherboard. Great board for the value.
You could get the 930 and save a bit, but I would buy the 950 myself. So far, for me anyway, ocing any i7 has been pretty easy.
Looks like a solid build. be sure to enjoy it and the resulting system. LLOOOVVE the building part myself.
Old November 19, 2010, 06:06 PM
ok thx for the heads up
ill go for the hx1000 seems like a good choice
for the other parts ill keep as is for now but depending wahts on sale for boxing day i may switch it up a bit
also need to buy a 3d screen and glasses.
any suggestions?
i saw asus has a 23inc 3d monitor for 380$~ and the glasses i didnt look up yet
Old November 19, 2010, 07:00 PM
any suggestions?
browse the bundles on NCIX. they usually got a 3d bundle kit on the go. ill see if i can find an example
EDIT: Here ya go NCIX.com - Buy NCIX 3D Bundle Deal Acer GD235HZ Bid 3D Ready 120HZ 23.6IN LCD 1920X1080 & NVIDIA 3D Vision Glasses - 3D Vision Acer GD235HZ BID In Canada.
Old November 20, 2010, 06:03 PM
oh nice!
thx
i read some reviews
ppl keep saying 28" would be better
should i wait
or get 3 screen or the panorama...
anyone have a link to a good package for panaroma 3d or 3 screens for 3d or a 28|in 3d screen i didnt find any on newegg
To build, or not to build: that is the question Timid newbe New Builds 5 August 12, 2010 04:33 AM
New Build- Corsair 800D --> My cleanest build ever. Watercooled btdvox Case Mods, Worklog & Gallery 28 May 11, 2010 01:07 PM
Windows 7 Build 7000 VS Windows XP SP3 Build 2600 Benchmarks Veritas Overclocking, Tweaking and Benchmarking 3 March 3, 2009 02:48 PM
