-   -   Computer upgrade and HTPC from recycled parts (http://www.hardwarecanucks.com/forum/new-builds/38111-computer-upgrade-htpc-recycled-parts.html)
Pax November 18, 2010 11:26 PM
I'm currently running a q6600 with 6gb of ram, and I'm looking to build an HTPC. I'm thinking I'll reuse the q6600 for my HTPC and some of the ram (sell the 755 mobo/extra ram) and upgrade to an 1156 processor/mobo/ddr3 ram for my main.
I'd like to keep costs as low as possible, and I'd like to overclock whatever 1156 setup I end up with. My main is water cooled, so no problem with heat from the OC. My main is used mostly for gaming and web/application development, which sometimes involves running a virtual machine as well. Some minor editing with photoshop too. I don't have any plans to SLI right now, but I might in the future. I currently have a 1gb 460.
Will the following HTPC setup be able to play HD video without any problems? I won't be getting a bluray, so all video will be stored on the HD, or on a computer on my home network.
Parts for my HTPC:
CPU: q6600 (have)
Ram 2gb (have...and will 2 gb be enough for win7/xbmc, or should I go with 4?)
Mobo: ASUS P5N7A-VM
Newegg.ca - ASUS P5N7A-VM LGA 775 NVIDIA GeForce 9300/nForce 730i HDMI Micro ATX Intel Motherboard
Case:
Silverstone Sugo or Silverstone Grandia 05B (depends where the htpc will end up)
NCIX.com - Buy Silverstone Sugo SG02B-F Black SFF mATX Case 2X5.25 2X3.5INT No PS - SG02B-F In Canada.
NCIX.com - Buy Silverstone Grandia GD05B Black HTPC mATX Desktop Case 1X5.25 2X3.5INT 1X2.5INT 3X120MM Fan No PS - GD05B In Canada.
HD:
WD 1TB Blue.
PSU:
Corsair 430CX
NCIX.com - Buy Corsair Builder Series CMPSU-430CX 430W ATX Power Supply Active PFC 120MM Fan *2 Year Warranty* - CMPSU-430CX In Canada.
After all this is pricematched it comes to about $389. Mobo is hte only thing not coming from NCIX, but there's free shipping, so its not a big deal.
For my new build:
4GB of G.Skill ram
NCIX.com - Buy G.SKILL F3-12800CL9D-4GBRL Ripjaws PC3-12800 4GB 2X2GB DDR3-1600 CL9-9-9-24 Core i5 1.5V Memory Kit - F3-12800CL9D-4GBRL In Canada.
CPU:
i3 540 (cheaper than 530 right now), unless there is a good reason to go with another cpu?
Motherboard:
Something in the $150 price range, unless it's overkill. Keep in mind, I would like to OC.
NCIX.com - Buy MSI P55A-G55 P55 ATX LGA1156 DDR3 2PCI-E16 2PCI-E1 3PCI SLI CrossFireX SATA3 USB3.0 Motherboard - P55A-G55 In Canada.
NCIX.com - Buy Gigabyte P55A-UD3 ATX LGA1156 P55 DDR3 2PCI-E 2PCI RAID GBLAN CrossFireX USB3.0 SATA3 Motherboard - GA-P55A-UD3 In Canada.
NCIX.com - Buy MSI P55A-GD65 P55 ATX LGA1156 DDR3 2PCI-E16 2PCI-E1 2PCI CrossFireX SATA3 USB3.0 Motherboard - P55A-GD65 In Canada.
Thanks for any input.
Reyzac November 19, 2010 04:45 AM
Nah, go with 4, I did almost exactly what you did and was told 2GB will not be enough for Win7.
Good choice on the new RAM, and I suppose that CPU should be good (OC IT!) What's your price range?
Pax November 19, 2010 07:50 AM
Alright, I'll be going with 4gb then. Thanks.
Overall price range, I'm hoping to be under or around $650 before tax. But if theres really good reason to spend more, I'd consider it.
The new parts I need for the HTP should cost roughly $300 (65 for case, 60 for HD, 45 for PSU, 130 for mobo)
For the upgrades for my main, I'll be looking at another $300-350.
150 for a mobo (recommendations are welcome...not sure what the best for OCing is at that range.)
120 for cpu if i get i3 540. Is there any value in getting an i5, or will a well oc'd i3 be good?
60 bucks or so for 4gb of ram.
JD November 19, 2010 08:32 AM
Why buy a new motherboard for the HTPC? Is the one you have currently broken? If not, I say just re-use it and toss a cheap GPU in there like a HD4350 or GT210.
Pax November 19, 2010 10:07 AM
Current motherboard (XFX 680i LT) is an ATX one and wont fit in either of the htpc cases. I'll either sell it or re-purpose it for something else.
Reyzac November 19, 2010 01:54 PM
Yeah, that i3 OC'ed nicely will do you good.
First board instinct would be the Sabertooth 55i. DOn't know if that's too much.
This guy here is on sale for a good price.
Or maybe this
Definitely get G.SKILL RAM at that price.
