Old November 11, 2010, 01:37 PM
Default Budget Build Need Help
Hi guys.
I am looking to build a budget rig in a few months and i dont know what parts i should get.
I have a budget of 600 and i wont nid things like a monitor,keyboard or a mouse
Please could you pick the parts from Microdirect.co.uk is the UK leading retailer of quality computer components and electronics
could you please also post the links of the parts you recommened for the build
thank you
Old November 11, 2010, 01:53 PM
hey dude. 600 pounds..roughly 1000 cad, should make a decent mid end machine.
what are you going to use it for? use percentages, like 90% gaming, 10% watching instructional material on the net,etc.
Old November 11, 2010, 02:01 PM
80% games
and the rest watching movies and net
and if you guys know any other good uk retailer website feel free to post
Old November 11, 2010, 02:16 PM
cool. and at what resolution will you be playing, will you want to max out the eye candy?
no idea on uk resellers.
i would go for something like a giga ud 3/4 p and i3 530/540 and perhaps a radeon hd 6850/6870. psu wise corsair,seasonic,antec 500-700 watts for dual cards
Old November 11, 2010, 02:25 PM
im playing on 2 23" monitors :P
and im planning on making a completely new build.. could u post links and the list of the parts needed pls?
Old November 11, 2010, 02:36 PM
ok, and what is the native resolution? 1920? 1440? big big difference with respect to video card selection
Old November 11, 2010, 02:52 PM
1920 :O
Old November 11, 2010, 02:53 PM
3.0charlie's Avatar
I like these guys better in the UK. And I must say the site you linked does not have much in way of choices...
Overclockers UK
Pre-built: "Titan Xenomorph" Intel Core i3 540 3.06GHz @ 4.20GHz Nvidia Edition DDR3 System []
And you can upgrade for 12 pounds to a GTX460, which is recommended.
Hydro-Quebec is salivating...
Old November 11, 2010, 02:58 PM
ya the site is pretty limited but its by far the best ive seen in the UK.. but if u have a better 1 feel free to post
Old November 11, 2010, 04:01 PM
ok so you want to run your games on dual 1920x1080/1200 monitors. it will take quite some gpu power, perhaps a 6850/70 setup might do it.
with the setup charlie linked you can crossfire. the 4x will take some fps out, but not an insane ammount
although its always better to build it yourself, saves you some cash usually.
Budget New build. luckiecookie New Builds 9 October 18, 2010 05:24 PM
Budget Build Paganitzu New Builds 4 March 14, 2010 03:23 PM
Budget build. Epmphasis on budget. Miek New Builds 6 February 4, 2010 10:46 PM
Budget build x2 Burkdaddy CPU's and Motherboards 0 January 27, 2010 08:24 AM
Budget build! JMCD New Builds 10 April 17, 2009 07:25 PM
