  #21 (permalink)
Old November 15, 2010, 04:52 PM
Originally Posted by jcmaz View Post
Yup
Sorry, then disregard my comment then..
I would draw air from inside the case just because there is less dust. The fan in rear is fine.
As for HDD mounting, if there is room in the bottom, then go for it. I'm sure it can fit there securely.
For speakers, you should buy them somewhere else. But if you need cheap one, then they are the ones to get.
Ah okay thanks for that. Btw just to be sure... the HAF92 has a bottom vent to mount a fan on.. would that make it a better choice than the HAF912?
  #22 (permalink)
Old November 19, 2010, 09:46 AM
Stay away from the new ATI line up in Crossfire.
Nothing but headaches and buggy performance.
If you want a strong single card solution, pick up a GTX580(for barely more than the two cards you're looking at) or wait and laugh at the new cards from ATI, and then buy a GTX580 anyways since it's the best bang for your buck if you are even considering crossfire/sli.
Bonus points: GTX580's in SLI down the road.
Help Build Gaming Rig a5un4k New Builds 10 September 9, 2010 11:09 AM
$2500'ish (broken budget already, 3K now) Gaming Build - Suggestions/Thoughts? Caldezar New Builds 57 August 15, 2010 03:23 PM
First ever Gaming rig build. gambel626 New Builds 5 November 2, 2009 08:32 AM
Going to build my first gaming rig Zankras New Builds 11 October 19, 2008 04:53 PM
Any and all thoughts welcome.. ( gaming build ) phatchantz New Builds 0 October 10, 2008 04:02 PM
