Old November 8, 2010, 11:24 AM
Default Doing a new build and I am kind of out of the loop, please help.
Hey everyone,
Doing up a new build and I am wondering if people had some thoughts on what I should get. I am really stumped on the Mobo/CPU combo I should get, along with ram I suppose. I am pretty much out of the loop where processors are at these days.
What I want is something that is cheaper but a great overclocker, when I orginally got my core2duo I got a e4500 and overclocked it to 3.2. At that point the e8600 wasn't out yet, otherwise I would have bought that.
I hear the i7 950 is one of the best for gaming, but the 930 is cheaper and I can easily overclock it to where the 950 is. I have no idea what i3 and i5 is all about.
Other parts I think I have already decided on is:
Evga GTX460 EE Super Clocked
and an SSD for my main hard drive.
I have used gskill ram and gigabyte mobos in the past, but don't know how they match up with all these other people making stuff for i5/i7 etc.
Any help would be appreciated.
Old November 8, 2010, 12:24 PM
well, what are you going to do with it, and your budget.
looks like you like intel, so the base would b an i3 530/540 mated to a nice lil giga board, ud3/4p will treat you good. 4ghz and spare of dual core hyperthreaded maddness :p
if your budget will not sink with the 930, then go for it. big fan of giga boards,so again try something like an ud3h. some here like the d-e from asus.
Old November 8, 2010, 12:28 PM
Budget is going to be 1000-1500 bucks... hopefully in the cheaper range.
Going to be gaming (lots of sc2, CS:S).. I know I don't need a super computer for either of those games but I want it to be a bit future proof (diablo 3?)
Audio recording/editing and (limited)Video recording/editing.
Thanks for the motherboard suggestion. I have been running a Gigabyte Ep45-DS3L for the longest time and it has served me well.
Old November 8, 2010, 12:42 PM
plenty. future proof? nein!
because of the video work you'll be doing, im thinking your 930 supposition might be right. you may also go with an nv card instead of a nice 6 series amd, sadly. why? well because of cuda.
1366
1156 if you decide on a nice hyperthreaded xeon 3440. will save you some 100 bucks with the board, maybe more depending o nyour choice, if you go that way.if.
cooler wise, cm 212+ as a minimum, or a nice fav on here v6gt, check ak's review.
some dude in the other thread is getting the ncix special, 930+ third party cooler @ 299 or something.
Another loop order, single/dual loop thread... turtletrax Water Cooling 8 July 28, 2010 08:40 PM
What kind of cable ??? Dan Troubleshooting 8 April 29, 2010 01:45 PM
What kind of pump for.... Charloz24 Water Cooling 13 March 25, 2010 10:07 AM
how about a contest of some kind ruffus Water Cooling 93 December 14, 2009 07:45 PM
What kind of PPD should I be getting? Daygard HardwareCanucks [email protected] Team 2 April 29, 2009 07:06 PM
