Old November 7, 2010, 01:28 AM
Nevakonaza's Avatar
Default "Upgrade" current system.
Hey guys,
You think this would be a good upgrade from my current Cpu,Ram and mobo?...in my system specs.
AMD Phenom II X6 1055T 2.8GHz 9MB Cache Socket AM3 Retail Box Processor
MSI 870-C45 AMD 870 Socket AM3 GB LAN 8 Channel Audio ATX Motherboard
G-Skill 4GB (2x2GB) DDR3 1600MHz/PC3-12800 Ripjaw Memory Kit CL7(7-8-7-24) 1.65V
Tks
Old November 7, 2010, 03:17 AM
I think the new upgrade will blow your current build out of the water.
Old November 7, 2010, 06:20 AM
martin_metal_88's Avatar
I would strongly conciderthis mobo since it will allow you to OC without blowing the VRM.
NCIX.com - Buy Gigabyte GA-890XA-UD3 AMD790X AM3 ATX DDR3 2PCI-EX 2PCI CrossFireX GBLAN SATA3 USB3.0 Motherboard - GA-890XA-UD3 In Canada.
You can also look at these one.
NCIX.com - Buy ASUS M4A89GTD PRO/USB3 AM3 DDR3 AMD 890GX ATX 2PCI-E16 PCI-E1 PCI-E4 2PCI VGA DVI Motherboard - M4A89GTD PRO/USB3 In Canada.
NCIX.com - Buy MSI 870A Fuzion ATX AM3 870 DDR3 2PCI-E16 Lucid Hydra 2PCI-E1 1PCI SATA3 USB3.0 GBLAN Motherboard - 870A FUZION In Canada.
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
Old November 7, 2010, 08:53 AM
Nevakonaza's Avatar
Really?....what sort of overclock do you think i could get out of that X6?
and whats the diffrence between the 1055T X6 and the 1075T X6?..is it just the 1075T is clocked 200mhz faster than the 1055T?
Thanks for the list,il look into them,the reason i choose that MSI board is because ive never had problems with MSI boards,It looks nice and is very cheap compared to the others ive been looking at.
Old November 7, 2010, 09:04 AM
sswilson's Avatar
Generally yes, but there's also the question of how much effort AMD is putting into the binning of their chips. The release of the 1055t /1090t procs is an example of this... when they were first released, there did appear to be about 200 mhz gap in overhead. Most OC reports on the 1055t had them averaging out around 3.8, while the 1090t chips seemed to be averaging out around 4G.
Are they still binning that well? Only time will tell.
Old November 7, 2010, 09:36 AM
well, what are you going to do with it?
if gaming, keep your system. rendering or something like that? go for the hexa. and you can keep the 870, very nice board. for heavy oc's direct a 120mm to blow on the cpu are(well left side more)
edit : the 870a from giga is the best of the bunch, go for that
ATI Overdrive "Current Values" Slik Video Cards 3 August 1, 2010 06:44 PM
Caught in a GPU Upgrade "pickle". Need Opinions .Frosty. New Builds 8 December 7, 2009 11:39 AM
[FS] Time to feed the "Need to Upgrade" Sale!!! mattlef Buy/Sell & Trade 16 August 1, 2009 03:15 PM
Continuous "Serious System ERror" BSOD, Reboots jazaddict Troubleshooting 20 December 31, 2008 08:26 AM
the system "you" wanted 6 months ago Krixxer CPU's and Motherboards 21 December 18, 2007 12:29 PM
