Old November 4, 2010, 07:19 PM
hmmm..if you really want the psu to last you(in terms of power) then get an 850, try to score an m12d on super special(was 99 at ncix and boy i got some more)
Old November 19, 2010, 08:08 PM
Just wanted to come back and say thanks for the help.
I used the same hardware as in the original post except I went with the i5 750 and a caviar black.
I wanted a midrange machine that was powerful and quiet, and it is definately quiet. As suggested, I will probably replace the fan on the cpu heatsink as it is the only thing I hear from the machine even under stress, though it is not a dire need. The case is def awesome.
The EVGA GTX 460 1gb is a rock. Idles at about 25-30 C and maxs at 50 under stress. The fan rarely goes above 30%.
And I guess I was lucky for a first build. Except for forgetting to plug in the CPU on first boot, everything went smooth.
Old November 19, 2010, 09:50 PM
rjbarker's Avatar
^^^ Glad to see it all worked out...its shear bliss when you hit that power button the first time and it Posts ;)
Classified Ultra SLi "Procyon"
http://i30.photobucket.com/albums/c3...2/DSC02888.jpg
http://i30.photobucket.com/albums/c3...2/DSC02889.jpg
Evga 4.2 Ghz Club....
Old November 20, 2010, 11:31 AM
fishingfanatic's Avatar
Smile New Builds
Definitely a solid build. Hope you don't get the build bug. I ended up with a house full of computers b4 I snapped out of it. hehe
First build, i5-750, all help appreciated µCephei New Builds 35 February 3, 2010 08:16 AM
Opinions of my first build? Munroe New Builds 2 November 5, 2009 08:35 PM
$1189CDN i7 Build, feedback very much appreciated! Major_Tom New Builds 34 May 6, 2009 06:25 PM
New i7 $2000 Build - Feedback Appreciated! Strato New Builds 11 April 25, 2009 07:05 PM
build advice appreciated Hreidmar New Builds 7 October 15, 2008 03:59 PM
