Old October 28, 2010, 10:55 AM
Default i3 530 software audio mixer build.
Building a 3U rackmount system to run a live mixing system. It doesn't need any video processing power and it will also be recording the audio to an external hard drive.
The audio software is call Sofware Audio Console
The only PCI card will be an RME HDSP 9652 Audio card that draws almost no power.
Here's the component list I've chosen that I've put into a newegg.ca wishlist
Open to questions or comments.
Old October 28, 2010, 10:01 PM
I'm not an audio engineering expert, but I'd suggest another PSU with better ripple control and better reliability. I see green tape in the picture for that Coolermaster so I'd assume it's a mid range CWT, not a bad unit but not the best either and it's $100. You could honestly run that build off a Pico PSU with a little undervolting. So either get a significantly cheaper/lower wattage Seasonic/Antec/Corsair or invest a little more into something like the X-560.
Old October 29, 2010, 07:46 AM
What do you think of this PSU?
Seasonic SS-560KM Active PFC F3, 560W
i3 530 build for a friend backpack New Builds 8 September 27, 2010 06:10 AM
Good free audio editing software?? somecanadianguy Audio 5 December 6, 2009 02:08 PM
Good audio software? Polygon O/S's, Drivers & General Software 2 October 31, 2009 09:17 PM
Advice on cheep mixer? Jack Rabbit Audio 11 July 19, 2008 01:51 PM
