Old September 24, 2010, 10:43 AM
Default Cross-Check before I finalize my order!!!
Hey Guys,
I'm going to purchase today! Please let me know if there are any items on this list that I should avoid, and the general quality of this build for around $1000. Want to be able to play SC2, Civ 5 and Diablo III when it comes out, other than that nothing should be too resource intensive.
Case - Antec 300
PS - Seasonic S12II 620W EPS12V 20/24PIN ATX Power Supply Active PFC 80+ Bronze 6+8PIN PCI-E W/ 120MM Fan
Mobo - Gigabyte H55M-USB3 mATX LGA1156 H55 DDR3 1PCI-E16 1PCI-E4 2PCI HDMI Sound GBLAN USB3.0 Motherboard
CPU - i5 760
Heatsink - CoolerMaster Hyper 212
Video - XFX Radeon HD 5770 850MHZ 1GB 4.8GHZ GDDR5 2XDVI HDMI Display Port DIRECTX11 PCI-E2.0
HDs - Kingston 64gb SSD and Seagat 1TB
RAM - G.SKILL F3-12800CL9D-4GBRL Ripjaws PC3-12800 4GB 2X2GB DDR3-1600 CL9-9-9-24 Core i5 1.5V Memory Kit
Any advice is appreciated... I think it's a solid build for $1000, let me know!
Old September 24, 2010, 11:03 AM
martin_metal_88's Avatar
Looking nice to me. The case is a bit old but if you like the look go for it. If you are open on a case I would try to see for CM 6902 basic or NZXT BETA EVO or CM 430 which are more recent case.
Old September 24, 2010, 11:08 AM
I've done a lot of reading on cases. I like the fact that it's super plain (much like flames on a car I find lighting in a computer lame) and I like the thickness of the case. I know the cable management can be a pain, but its a pretty basic build so it shouldn't be too much of a hassle.
I will however check those cases out because I like knowing what's out there.
Old September 24, 2010, 11:36 AM
Bond007's Avatar
Looks solid. If you have a few extra dollars I would grab a 460 768mb or 1gb, but if not the 5770 should run those games no problem (as long as you don't use really high resolutions). Nice choices.
EDIT: I am the same way about cases and think the 300 is a great case for the price (I have one and you already know its main flaw).
Old September 24, 2010, 11:40 AM
you may want to check out the ps04b, cm 912 as well not too far from the above price point wise.overkill,but really nice psu.
Then if you like the case there is nothing more to say Hit the order button.
here are also some few option if you prefer clean look. If you can make them fit in your budget.
http://www.ncix.com/products/index.p...actal%20Design
http://www.ncix.com/products/index.p...e%20Technology
http://www.ncix.com/products/index.p...e=COOLERMASTER
http://www.ncix.com/products/index.p...acture=LIAN-LI
Don't forget to make a workblog out of this build!! with lot of picture
Old September 24, 2010, 11:53 AM
dangtx, NCIX had a bundle deal that was over 30% off on that PSU. I'd be getting it for about $65... otherwise I wouldn't haha.
Bond007, you mentioned spending a bit extra on a 460... can you or anyone else elaborate on the major advantages of these cards compared to the 5770??
Thanks guys! I will document the build... should provide some good insight for people keeping it simple.
EDIT: I just remembered that on NCIX, the XFX 5770 has a $40 IR and 20 mail-in... I think that's what originally was driving my decision.
Old September 24, 2010, 11:56 AM
A 460 1GB will ( at high res ) at 1200, give more juice then a 5770. But, as long as you keep the screen around at a 1080 res you will be fine with both card. Especially if you want to play D3 which will be a pretty light game...In your situation I see no point of a 460 since the price difference can be pretty huge, a 5770 can be add for around 160 and a 460 1GB around 250.
Old September 24, 2010, 12:07 PM
basically the 460 oc'ed will handle better than the 5770.
65 is a very nice deal, good for future upgrades.
Old September 24, 2010, 01:13 PM
fishingfanatic's Avatar
Smile New Builds
I would consider the OCZ Vertex II SSD over the kingston. Better drive. +1 4 the 460, though the deal sounds sweet 4 the 5770. Looks like a good build.
Going out to finalize a folding box. Need recommendation chrisk HardwareCanucks F@H Team 127 January 2, 2011 10:45 AM
new to cross fire have a question or two Shadowmeph Video Cards 1 May 5, 2010 10:58 AM
Help me finalize my 1st build #2 kaufman37 New Builds 22 August 21, 2009 10:17 AM
Help my finalize my 1st build kaufman37 New Builds 20 August 18, 2009 11:10 PM
Help me Finalize my 1st Build kaufman37 New Builds 8 August 9, 2009 10:45 AM
