Old September 17, 2010, 05:42 PM
bf1 bf1 is offline
Default First Time Build!, tell me what u think!
Give opinions and suggestions pls ;D
What do u think! Good or not?
MOBO: ASUS P7P55D-E Pro - http://ncix.com/products/index.php?sku=48014
CPU: I5 760 - http://ncix.com/products/?sku=54753&...ufacture=Intel
RAM: G.SKILL Ripjaws Series 4GB http://www.newegg.ca/Product/Product...82E16820231277
GPU: Gigabyte GeForce GTX 460 x2 SLI http://ncix.com/products/?sku=54506&...cture=Gigabyte
HDD: Western Digital Caviar Black WD5001AALS 500GB Newegg.ca - Western Digital Caviar Black WD5001AALS 500GB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
PSU: Corsair CMPSU-750TX http://www.newegg.ca/Product/Product...82E16817139006
CASE: HAF 932 http://www.newegg.ca/Product/Product...82E16811119212
Old September 17, 2010, 05:50 PM
welcome aboard maite.
look ok, perhaps get the 922 case wise
caviar green will be a bit slow, maybe try the sammy f3,wd black or seagate in the same gig range?
nice psu, a little bit too much for dual 460's :)
Old September 17, 2010, 06:01 PM
bf1 bf1 is offline
oh ya, lmfao i forgot to change the Harddrive, a friend already told me that it would be a bit slow lmao, but thank you for advice ;D
Old September 17, 2010, 06:54 PM
no worries. intel still holds better performance per core per ghz, so a 530 on a nice sli matx giga board might work out as well. comparing vs the coolermaster 932 amd build vs cm 922 build, comes about the same. more performance, and it wil lclock to 4 ghz +- on stock cooling. dont forget a cm 212+ for cooling, monster cooler for under 25 bucks pm'ed(price matched at ncix)
Old September 17, 2010, 07:35 PM
bf1 bf1 is offline
alright, thanks man
Old September 17, 2010, 07:49 PM
martin_metal_88's Avatar
hm, why put 2X video card with this CPU? if you play game your CPU is gonna limit you. I would drop one of the video card, and get a X4 or a X6 instead and add another GPU later if really needed. The other part are ok. Maybe you could also look at never chipset 8XX series on AMD since the 750 is pretty old.
Old September 17, 2010, 08:02 PM
bf1 bf1 is offline
lol so instead of athlon x3, athlon iix4??
Old September 17, 2010, 08:07 PM
http://ncix.com/products/?sku=54097&...SI%2FMicroStar
http://ncix.com/products/?sku=52682&...nufacture=eVGA
http://ncix.com/products/?sku=48959&...ufacture=Intel
price match them.
that or stick with the amd, although maybe get a model number 240/250 cpu? :)
Old September 17, 2010, 08:16 PM
No, Phenom 2 X4 or X6 or Intel I5. Athlon are the low end. Mainly made for HTPC or internet use computer.
Old September 17, 2010, 08:19 PM
martin dont diss the performance per dollar of the athlon, he can get amd sli mobo+cpu for 150-160 or close. :)
First time build soambiatch New Builds 7 August 25, 2010 05:56 PM
$1000 Build - First time Help Cdnjunkie New Builds 10 May 7, 2010 08:40 PM
First Time Build pRefy New Builds 40 March 22, 2009 12:52 PM
First Time Build Need Help and Opinions Modestyle New Builds 35 February 28, 2009 05:30 PM
First time build CGW Troubleshooting 10 September 12, 2007 07:27 PM
