  #41 (permalink)
Old September 20, 2010, 02:08 PM
my next project will be to try,blindly at that, the sli hack thingie on whatever amd mobowith 2 or more pci-e slots i can (very) cheaply get my hands on. ill be doing some benches and compare them(depending if ill have a proper factory enabled sli mobo to compare with) :)
to prove a point. the only unsure thing is the unknown success rate in the wild, thus cannot recommend it 100% . although with the newer one chances should be better than before.
  #42 (permalink)
Old September 25, 2010, 11:39 AM
bf1 bf1 is offline
lol i think im going to change the mobo and cpu to
I5 760 - http://ncix.com/products/index.php?sku=54753
ASUS P7P55D-E Pro - http://ncix.com/products/index.php?sku=48014
The i5 760 > 965 no? and my total is practically the same price
  #43 (permalink)
Old September 25, 2010, 12:19 PM
If the total is around the same price, then go with the i5 760 & Asus P7P55D-E Pro, especially since your planning on going with 2 GTX460 1GB cards in SLI.
  #44 (permalink)
Old September 25, 2010, 12:23 PM
werent you going 1366? kind of got lost in here. if its more or less the same, price wise (doubt it but still) go 1366
  #45 (permalink)
Old September 25, 2010, 01:18 PM
bf1 bf1 is offline
0.o? i was never going 1366 lol..why go 1366
First time build soambiatch New Builds 7 August 25, 2010 05:56 PM
$1000 Build - First time Help Cdnjunkie New Builds 10 May 7, 2010 08:40 PM
First Time Build pRefy New Builds 40 March 22, 2009 12:52 PM
First Time Build Need Help and Opinions Modestyle New Builds 35 February 28, 2009 04:30 PM
First time build CGW Troubleshooting 10 September 12, 2007 07:27 PM
