Originally Posted by _dangtx_ martin dont diss the performance per dollar of the athlon, he can get amd sli mobo+cpu for 150-160 or close. :) |
I know that dan, but would you buy a E5300 with 2 video card? that's the point where I am blocking. Why get a low end CPU with 2 video card? that will bottleneck for sure. it's like towing a fifth wheel with a Accent GL...to be good, a build have to be balanced or suited to your need. If you want to play, you need both CPU and GPU power. here you have a lot of GPU power but low end CPU. You can for sure go for the athlon but when you will try to play high end game at high end res don't ask us why you have some lag.
