Old August 30, 2010, 04:51 PM
Default extreme budget build
By extreme i mean extremely cheap,So i'm going to build a family pc for general use(light gaming possibly).Here is my list of parts to buy....
AMD phenom II x2 550-$89.99
thermaltake v3 case--$44.99
seagate 250gb hdd-34.99
BFG GX 550 Watt power supply-$30(i know i should get a better quality psu,getting it to power this build for a few months tops)
corsair 2gb ddr2 ram-$44
I already have the mobo and dvd drive and a cheap gpu
biostar a785ge i believe it is
don't remember the brand of dvd drive
ati 4650 1gb
GRAND TOTAL =$293.97 including mobo and shipping/tax
comments/suggestions welcome.I want to keep this pc under the $350 mark
Old August 30, 2010, 04:56 PM
fishingfanatic's Avatar
Smile New Builds
Only thing I would suggest would be to look in the BST threads for components. You might get better for about the same money.
Old August 30, 2010, 05:03 PM
jcmaz's Avatar
I don't know if you can return the bought items, but i would have gotten a motherboard with integrated video card instead.
AMD Athlon X3 ~$75 CAD (probably cheaper in the States)
Silverstone PS04B
How bout a Sparkle 350W or a Seasonic 350W?
-Plato
Old August 30, 2010, 05:09 PM
would search around but i need to build this pc quick
Old August 30, 2010, 05:11 PM
Silverstone PS04B
It does have intergrated graphics,but i have the 4650 from awhile.why not use it right?
Old August 30, 2010, 05:16 PM
extreme or just on the low end would be a celly 3300 pmed udner 50, same with a nice asus or giga board around 50 buckers.
the rest is your choice, just dont get a 2 dollar psu
ps ps04b
Old August 30, 2010, 05:59 PM
Personally I would go with an athlon II x3 instead of the phenom II x2, but that's your call (would save a few bucks too). And you could consider a cooler master rc-330 (elite 330), or one of the other budget cooler master cases (I used one last year for a build, and its fairly thin metal, but worked great for a budget build...think I got it for $34 price matched). Spend a couple extra bucks on a seasonic 350w, corsair 400w, or antec earthwatts 380 or higher.
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Old August 30, 2010, 06:48 PM
well i'm buying either an athlon or phenom x2 with the hope of unlocking a 3rd or forth core.I'm getting an ULTRA 550 Watt psu instead
Old August 30, 2010, 07:09 PM
I think ultra may be even worse then BFG (someone else chime in if I'm wrong).
Old August 30, 2010, 07:12 PM
how bout just a refurbed ibm s50, they go for like 150 bucks or so, if you can still find em. great litte internet machines
vista 64 on these rigs
Q9450 @ 3.5Ghz | E8400 @ 4.2Ghz
8gb Muskin Redline. | 2gb Kingston Hyperx
________________________________|_________________ ______________
EVGA 780i FTW ----\--||___||--/---- EVGA 780i SLI
Antec TP Quatro 1000W \ :==^==: / Antec TP Quatro 850W.
Nvidia 9800 GX2 X 2 SLI \|--o--|/ Nvidia 8800 GTS X 2 SLI
1X 500GB Western Digital. \_____/ 3X 150GB WD RAPTOR RAID-0
Budget build. Epmphasis on budget. Miek New Builds 6 February 4, 2010 09:46 PM
Budget Build x 2 Burkdaddy New Builds 4 January 28, 2010 07:18 AM
Extreme i7 build sc00byy New Builds 127 April 19, 2009 04:55 PM
Budget build! JMCD New Builds 10 April 17, 2009 07:25 PM
Extreme OC Build Infiniti New Builds 6 September 29, 2008 10:11 PM
