Old August 30, 2010, 07:14 PM
Originally Posted by Bond007 View Post
I think ultra may be even worse then BFG (someone else chime in if I'm wrong).
No, you're right. Ultra PSUs for the most part are garbage.
Old August 30, 2010, 09:20 PM
ok,I'm getting a corsair 430 watt
Old August 30, 2010, 09:24 PM
You'd be better off with this: Newegg.ca - Antec NEO ECO 400C 400W Continuous Power ATX12V 2.3 / EPS12V 80 PLUS Certified Active PFC Power Supply
Old August 31, 2010, 06:33 PM
Bond007's Avatar
I am sure this is a decent PSU (hopefully since its corsair and it will be better than the others you chose so far), but the new 430w corsair (I have read) is inferior to the older 400w.
Also +1 for the antec neo eco as a good choice to add as a possible.
Old September 1, 2010, 08:59 AM
jcmaz's Avatar
Newegg.com - SeaSonic SS-400ES Bronze 400W ATX12V v2.31 80 PLUS BRONZE Certified Active PFC Power Supply - Power Supplies
Seasonic 400W PSU at around $50. Or you could get a Sparkle 400W for $10 less.
Newegg.com - SPARKLE ATX-400PN-B204 400W ATX 12V 2.01 Power Supply - Power Supplies
-Plato
Budget build. Epmphasis on budget. Miek New Builds 6 February 4, 2010 10:46 PM
Budget Build x 2 Burkdaddy New Builds 4 January 28, 2010 08:18 AM
Extreme i7 build sc00byy New Builds 127 April 19, 2009 04:55 PM
Budget build! JMCD New Builds 10 April 17, 2009 07:25 PM
Extreme OC Build Infiniti New Builds 6 September 29, 2008 10:11 PM
