Stuck... Hello, this is my first thread on HWC, and I am glad to be part of this community. So, I am running possibly the world's crappiest custom-built computer, and I thought I had a selection of parts made out for a new one. This will not be my first build (far from it, more like my 13th, I believe) but I am stuck on a parts decision, specifically concerning the Mobo/Proc/GPU relationship. My original list had: MSI P55-GD65 LGA 1156 Intel Core i5-750 MSI HAWK Radeon HD 5770 I would love to be able to run CFX with the Hawks, but the :censored: P55 chipset only has 16 PCIe lanes. No, I can't afford LGA 1366, I would prefer to not have AMD at this budget (maybe as a last resort) but as far as I can see this leaves me with no options. Help? If this helps, I am an avid gamer who will end up running the games listed in my sig and some others, plus need to have enough power for newer games that come out, such as MoH. |
you can crossfire on p55, x8 to x16 wont make much fo a difference, at normal resolutions |
Welcome to the forum! If you want to CF 5770 who give a **** ABOUT 16 PCI lane? The second card on the 8X wont even be bottlenecked. So P55 is still perfect. Or if you absolutely want to have 2 then get a 5850 and OC the hell out of it it will be a better solution. I would also concider Asus P7P55D and EVGA P55 like this one. Newegg.com - EVGA P55 SLI 132-LF-E655-KR LGA1156 Intel P55 ATX Intel Motherboard They actually are better then MSI. |
There's nothing wrong with Crossfire using two 8x slots. At most resolutions you won't see a performance difference. However, I would recommend that you switch to a GTX 460 instead of the 5770, preferably a 1GB model. That would give you considerably more performance. |
Thanks for the help, guys, and martin, I'll make sure to take a look at that. I mainly went for a 5770 because of the value, a GTX 460 is a little bit much for my budget. :blarg: How big of a perf difference can I expect with x8/x8 rather than with x16/x0? (BTW I know you can CF with 8x, it was the performance difference I was worried about.) |
well its more expensive but its got more humph as well. eats a bit more power, but you can probably do with that |
I think it only matter's when running high res with high-end cards. GTX 480 SLI x16/x16 vs. x4/x4 - GTX 480 SLI PCIe Bandwidth Perf. - x16/x16 vs. x4/x4 | [H]ard|OCP |
I personally think that if you can afford two 5770, why can't you get a single 460? Less power consumption and less head aches on Crossfire. And honestly, i would get a more "upgradeable" system (socket AM3) than the soon to die LGA1156 and spend more on graphics. Plus MoH isn't demanding at all, it is just like BFBC2 without the Destruction 2.0. |
| All times are GMT -7. The time now is 02:56 AM. |
