Old August 24, 2010, 07:37 PM
Default First time build
Hello, I,m a n00b . Building my first PC . In the next couple of months ( October ) Right now I have a HP Pavilion a250n ,upgraded Intel 3.2 GHz Northwood ,Windows XP ,Ram at 1500 MHz ,GPU ...Asus AH2600pro. And a Cheap ( No Named 450w PSU )
I play games ,Counter Strike Source, Call of Duty , And Ghost Recon, And just web surf ,Watch movies , no video editing . I can only get DSL High Speed Internet no Cable ....
I would like to buy all my components from newegg.ca or NCIX.
Based on a 890fx AM3 board
Case ~ Lian Li Lancool PC-K62
Motherboard ~ Asus M4A89TD Pro ? ( Issues with NB Heat on Asus Crosshair 4 and MSI 890fxa-GD70 )
Processor ~ AMD Phenom II X4 ( 955 - 965 (c3 ) ( 1055T ~ 1090T ???) ( No Need for 6 cores ??? )
CPU Cooler ~ Zalman CNPS9900ALED ( Corsair H50 - H70 ??? )
RAM ~ G.Skill 4GB (2 x 2 GB ) F3-1600CL9D-4GBRH
Video card ~ MSI R5770 Hawk ...Crossfire X in the near future...
PSU ~ Corsair HX750w ( Can I swap out fans on a psu ??? )
HDD ~ Western Digital Caviar black ( 640 GB ) 7200 RPm
OS ~ Windows Home 7 - 64 Bit
Monitor ~ I'll buy From Dell ? OptX AW2210 21.5" ?
Keyboard ~ Alienware TactX ???
Mouse ~ Alienware TactX ???
Thanks to all ...Cheers ...
Old August 24, 2010, 08:33 PM
hmmm...no
giga 870a
a duallie for now i say, 240/250
coolermaster 212+
one gtx 460 now and maybe none later?
nice psu, wayy overkill. yes, if you want to void warranty :)
maybe try that or the sammy f3?
samsung 24" lcd good and cheap
kb and mouse..cant help you there
Old August 24, 2010, 09:24 PM
ok here is what I recconmend.
NCIX.com - Buy MSI 870A-G54 ATX AM3 870 DDR3 2PCI-E16 CrossFire 1PCI-E1 3PCI SATA3 USB3.0 GBLAN Motherboard - 870A-G54 In Canada. $112.42 cheper and usb 3
NCIX.com - Buy Coolermaster CM 690 II Advanced ATX Mid Tower Case Black 4X5.25 1X3.5EXT 6X3.5INT *No PSU* - RC-692-KKN2 In Canada. $101.99 it is one hell of a case for the $
NCIX.com - Buy MSI GeForce GTX 460 Fermi Cyclone OC 725MHZ 1024MB GDDR5 Dual DVI Mini-HDMI DX11 PCI-E Video Card - N460GTX Cyclone1GD5/OC In Canada. $254.99 at this time it is the only way to go
NCIX.com - Buy Noctua NH-U12P SE2 LGA775/1156/1366 AM2/AM3 I7/I5/PHENOM Heatpipe Cooler W/ 2XNH-P12 120MM Fans - NH-U12P SE2 In Canada. $79.99
NCIX.com - Buy Western Digital WD20EARS Caviar Green 2TB SATA2 3GBPS 64MB Cache 3.5IN Hard Drive OEM - WD20EARS In Canada. $99.99 you will thank me later
NCIX.com - Buy Corsair Professional HX750W 750W ATX 12V 62A 24PIN ATX Modular Power Supply Active PFC 140MM Fan - CMPSU-750HX In Canada. $199.99 do not open it.
NCIX.com - Buy Microsoft Windows 7 Home Premium Edition 64BIT DVD OEM - GFC-00599 In Canada. $123.99
NCIX.com - Buy G.SKILL F3-12800CL9D-4GBRL Ripjaws PC3-12800 4GB 2X2GB DDR3-1600 CL9-9-9-24 Core i5 1.5V Memory Kit - F3-12800CL9D-4GBRL In Canada. $96.99
NCIX.com - Buy Samsung E2320X 23IN Widescreen LCD Monitor 1920X1080 5ms 16:9 70000:1DC DVI VGA - LS23CLZSFV/ZA In Canada. $189.99
NCIX.com - Buy Logitech G110 Gaming Keyboard USB Programmable RED/BLUE Backlit Keys USB Audio *European Version* - 920-002233 In Canada. $99.99
NCIX.com - Buy Steelseries Kinzu Optical 3 Button Gaming Mouse USB - Kinzu In Canada. 39.99
all in you are looking at $1608.51
Old August 24, 2010, 09:44 PM
Originally Posted by _dangtx_ View Post
hmmm...no
giga 870a
Hmmm... No. It looks like the OP is trying to build a moderately-powerful system, and you're suggesting low-end budget hardware? If anything, I would recommend upgrading to a better video card like a GTX 460 or 5850 and a better CPU like a 1055T or 1090T.
Old August 24, 2010, 10:54 PM
jcmaz's Avatar
I personally find it pointless to get a top of the line mobo if you are a mild overclocker or don't need tri sli/xfire.
I would get the 870G mobo that was reviewed here and a Phenom 945.
Drop the Zalman cooler. Get a CM 212+ for ~$30.
Drop the 5770 and get a 460 1GB version from EVGA.
Yes it is possible but you might electrocute yourself :(
-Plato
Old August 25, 2010, 10:36 AM
fishingfanatic's Avatar
Smile New Builds
All great suggestions! I'm leaning on the EVGA as well, the 1 gb version for the lifetime warranty. I still like the 1055T as it's close to the same price as a 965.
Case choice is subjective, but I agree that the Cooler Master series are pretty good, though Lian Li are a good quality unit.
I agree with the others that you should have a bigger HDD like a 1 tb minimum. Samsung is the fastest, and WD is very good as well.
For a noob, you've picked some good components. B4 pulling the trigger, check out the reivews of components. This could sway you with your final decision also.Cpu cooling should be looked at as well.
Good luck with the build and enjoy the new system!
Old August 25, 2010, 11:49 AM
I would change the cpu cooler to the CM Hyper 212 Plus & the HD5770 to a GTX460 (either of the 2 are good) like others have suggested. If you wish to stay with ATI then I would suggest the 5830 or 5850 as those are competitive with the 2 GTX460's.
I would take up the samsung suggestions as well, due to my preference for their awesome monitors
Also the 1055T would be a sweet cpu to get, 6 cores is hard to argue with especially when you can only get a quad core from Intel for the same price and similar performance!
As for the keyboard & mouse, I prefer logitech, my current fav is the MX5500.
Everything else is all good, good luck with your build mate
Old August 25, 2010, 05:56 PM
O.K. thanks everyone . The hyper 212+ is a must and the 1055t and the Samsung HDD,And I,ll probaly go with the 5850...Thans to all ...
First build in a long time lastsplash New Builds 3 November 8, 2009 09:12 PM
New build in a long time!!! Delavan New Builds 7 April 10, 2009 07:09 AM
First Time Build pRefy New Builds 40 March 22, 2009 12:52 PM
First time gaming build. How's it look? hone0041 New Builds 21 October 11, 2008 02:51 PM
First time build CGW Troubleshooting 10 September 12, 2007 07:27 PM
