Yes, another P6X58D-E fan and owner. Great motherboard! Again, as per a previous member, case selection is subjective. The CM HAF series cases are good, with the new X having usb3 and sata3 with 2 hot swap bays in the front of the unit. These cases are also very roomy for ease of use. The NZXT cases are good, Lian Li are a bit pricey but well made, and the Corsair cases are great for watercooling setups.
For gpus another fan of the 460 1gb models with EVGA having the lifetime warranty as was mentioned, 2 460s in sli outperform a single 480. They also run cooler and use less power individually, not sure about collectively.
I'm a Mushkin fan when it comes to memory, but any lifetime warranty ram is pretty good including Patriot,Corsair and G Skills.
I would recommend Corsair psus, the modular ones, HX or AX series. Silverstone are good and while there are a few others, none comes to mind atm.
Overall, it sounds like you should have a petty decent system when done. Enjoy the build and new system!!!
