<~----> My i3 System (Building in 1-2 weeks) - Hardware Canucks
Old August 12, 2010, 07:56 AM
Default My i3 System (Building in 1-2 weeks)
I want to start building a new desktop in 1-2 weeks, and I think I've finally settled on parts. I just want to see what everybody thinks before I go ahead and buy something that might not be worth it. I'm buying from a wholesaler so I can get things for a bit cheaper, however I'm a little limited in my selection of parts (they only carry newer ATI cards and not nVidia, and only newer intel cpus instead of AMD). All prices are in CAD.
Edit: Updated the List with Most Recent Decision (8/15/2010)
Case: COOLER MASTER RC-692-KKN2 CM690 II Advanced
CPU: Intel i3 530 2.93GHz
Cooler: Coolermaster Hyper 212 Plus
GPU: EVGA 768-P3-1360-TR GeForce GTX 460 (Fermi) 768MB
Motherboard: ASUS P7H55/USB3 LGA 1156
RAM: G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600
PSU: Antec NEO ECO 520C 520W Continuous Power ATX12V v2.3 / EPS12V
HDD:Seagate ST31000528AS 1TB SATA 3Gb/s 7200RPM 32MB
OS: Windows 7 Ultimate 64-bit (get this free from my school because I'm in Electrical Engineering)
Total: $965 w/ Shipping & Tax
I'm just going to use a DVD Burner from one of my old PCs.
The system will be used primarily for gaming, and I would like to keep the system around the same cost.
Old August 12, 2010, 11:13 AM
heya. you might actually use a retailer and get more choice.
is this a gaming machine? if so at what resolution will you be playing?
not too sure bout that psu,case.
Old August 12, 2010, 11:44 AM
The system is going to be used primarily for gaming at 1680x1050.
Another option for the PSU I've been considering is a corsair 450w (CORSAIR CMPSU-450VX 450W)
Old August 12, 2010, 11:54 AM
Despicable's Avatar
Yea thats much better.. corsair is a much better brand
EDIT: NCIX has that PSU on sale for 64.99 and u get a MIB for 20 bucks making 44 dollars in the end
Old August 12, 2010, 11:58 AM
rapmaster's Avatar
Get a GTX 460 instead, it cost only a bit more.
Quando omni flunkus moritati
Old August 12, 2010, 12:46 PM
I just checked NCIX, and it appears that the PSU is 64.99 AFTER the MIR, and newegg has a $15 MIR, making them exactly the same price.
Here is a new PC entirely from newegg that I experimented with, it's $50 more than my other one, but I think it has some better part selections.
Case: Antec Three Hundred Illusion Black Steel ATX
HDD:
SAMSUNG Spinpoint F3 HD103SJ 1TB
PSU:
CPU:
Intel Core i3-530 Clarkdale 2.93GHz
GPU:
RAM:
Motherboard:
ASUS P7H55/USB3 LGA 1156 Intel H55
OS: Windows 7 Home Premium 64-bit
Old August 12, 2010, 12:53 PM
because of the 1680 resolution the 768meg card is fine. or you could spend 20 more bucks and have a bit higher framerates? :)
http://tpucdn.com/reviews/Palit/GeFo...es/perfrel.gif
http://tpucdn.com/reviews/Palit/GeFo...rfrel_1680.gif
edit. heck, if i were you id go amd because its uber cheap. and keep the 1gig 460.
Old August 12, 2010, 01:09 PM
I have no idea where to even begin with AMD though. If I could get some recommedations for a cpu/motherboard that would be great :)
Old August 12, 2010, 01:32 PM
Despicable's Avatar
u didn't go into the sale on the home page of ncix.. thats why ur not seeing it for 44.99
Old August 12, 2010, 01:53 PM
well, cheap cheap would be a 240/250 because of the good oc'able c3 core and a giga board, anywhere from mid 70's to around 100 bucks for a killer 870a giga branded of course. killer. look up sky's review of the monster
Building a new I7 system billionaireclub New Builds 10 February 21, 2010 05:26 AM
Building a budget system around a 4850x2 Vethrik New Builds 14 March 5, 2009 04:49 AM
Building a new system $2800 budget probationer New Builds 51 November 3, 2008 01:35 PM
Building a gaming system around 1200$ Muad'Dib_53 New Builds 4 August 9, 2008 04:30 PM
Building a Dual Socket System Paul Rogers CPU's and Motherboards 8 February 6, 2008 04:01 PM
