  #31 (permalink)
Old August 16, 2010, 06:08 AM
well the first thing is to reach a max limit on stock all.prime+3dmark loop stable, maybe some winrar in the background with a spice of antivirus scan as well. then you raise slowly till you need to drop more juice than the last 50mhz or so to get forward. thats nearing the limit on your present cooling.
  #32 (permalink)
Old August 16, 2010, 06:40 AM
Realityshift's Avatar
I was running my i3 right up to 1.55, but if you stay around or under 1.5 I believe is fine, they start with a decently high starting Vcore anyways. Just step it up slowly and watch your heat which will be the real killer to your CPU, it should do 4ghz with pretty low temps (50c or so) but as you bump it closer to 4.5ghz the heat dump really starts to show.
The Builders Hammer
  #33 (permalink)
Old August 16, 2010, 07:57 PM
Just ordered my parts from Newegg & Direct Canada. The CM Hyper 212+ was sold out in all the cheap sites, so I'm going to use stock cooling for the time being and order the 212+ after I've started school.
Final Parts:
Case: CoolerMaster 690-II Advanced
Motherboard: ASUS P7H55/USB3
CPU: Intel i3 530
GPU: EVGA GTX 460
HDD: Seagate ST31000528AS 1TB SATA
RAM: g.skill Ripjaw 4GB DDR3 1600MHz
PSU: Corsair TX750 750W +12V 60A
I decided to go with a more powerful PSU to accomodate future upgrades, rather than having to replace it when I buy something new.
  #34 (permalink)
Old August 16, 2010, 08:02 PM
shayan288's Avatar
Go for a 460 1gb version. The price difference isn't TOO big and it can actually compare with the 470 when overclocked.
The 288
Q9550 E0 stepping @ 4Ghz
Gigabyte EP45 UD3P
G.Skill pc2 8500 1066mhz RAM
Western Digital 250gb
Antec 1200
XFX HD5970
Steelseries Xai Laser Mouse
Windows 7 Ultimate x64
Building a new I7 system billionaireclub New Builds 10 February 21, 2010 06:26 AM
Building a budget system around a 4850x2 Vethrik New Builds 14 March 5, 2009 05:49 AM
Building a new system $2800 budget probationer New Builds 51 November 3, 2008 02:35 PM
Building a gaming system around 1200$ Muad'Dib_53 New Builds 4 August 9, 2008 04:30 PM
Building a Dual Socket System Paul Rogers CPU's and Motherboards 8 February 6, 2008 05:01 PM
