Old August 10, 2010, 10:14 PM
Default HELP, with new PC build.
Hi guys, I would greatly appreciate if you guys could help me out.
Gaming, web surfing. Movie watching. Windows Server 2008 R2 hyper v. with 4 or 5 virtual machines running at once.
300-400 for cpu, 200-400 for motherboard, 500 and under for RAM (for amd want 2X4GB and for i7 not sure, but want to run tripple channel obviously and at least 8 gigs also).
150 and under for blu-ray Rom/dvd writer combo (not sure if i should buy a blu-ray reader as I am not sure if the firmware will be upgraded for new movies if drives get discontinued).
Canada NCIX/newegg.
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
None, just want best for the price and for virtualization in windows server 2008 r2 hyper v.
Parts I have are shown below:
*mouse/keyboard
*Coolermaster haf-x 942 xl-atx case.
*1TB WD HD sata3.0
*120 GB Crucial RealSSD C300 (sata 6GB/s)
*Corsair HX Series CMPSU-850HX 850W atx12v 2.3, 80 plus silver certified modular active pfc power supply.
*logitech z-5500 sound system/speakers.
Yes, but lots to take in.
Yes, Never OCed before but want to try a mid level OC
middle to late August 2010
9. What resolution do you use?
I have a Dell u2711, resolution is 2560 X 1440
Old August 10, 2010, 11:35 PM
930 on a ud3h giga? either 6 or 12 gigers fer dual chan.
or 870a with a 1055t? 2x4gb ok, oc might be limited
good choice of psu. overkill unless you get dual 480's or tripple 5870's or something. best band per buck in a multi card setup seems to be 2 of them.
Old August 11, 2010, 01:44 AM
dr_dream's Avatar
Go with a Intel Core i7 930 2.80 GHz ($290), which overclocks easily pas 4 GHz (reviews), paired with a Gigabyte X58-UD3R ($210) motherboard (reviews) and an OCZ Reaper Edition 12GB (3x 4GB) DDR3 1333MHz memory kit ($300).
PC-Waves.com
Old August 11, 2010, 02:46 AM
kendallcschm's Avatar
Originally Posted by dr_dream View Post
or for 300 $$ on a processor you can do the black edition AMD hexacore processor. more cores... it over clocks very well according to the reviews on new egg and having a hexacore just sounds awesome
Old August 11, 2010, 06:05 AM
fishingfanatic's Avatar
Smile New Builds
Good list of components. I like core i7 where the 930 is a good choice. However, if you want AMD, then imho the 1090T as mentioned by another member is a viable choice. My preference for ram is Mushkin, Patriot, Corsair, or G Skill.
For mobo, my preference is Asus P6X58D-E. This is a choice based on features. For AMD, Asus is once
again my preference. The Gigabyte boards are a good choice as many members recommend those.
Whatever you choose, the new usb/sata components you own allows you to take advantage of their increased features.
Old August 11, 2010, 07:39 PM
Thanks for the speedy responses guys.
I am still torn as to going AMD 6core vs i7-930.
For virtualization/movie watching, which do you suggest of the two?
Also, which platform is less likely to have issues with RAM compatibility?
Old August 11, 2010, 07:59 PM
alsp, intel build if you wamnt maximum performance out of your hdds, be it regular or ssd.
does it make a difference for the regular guy? maybe not.
Old August 11, 2010, 08:36 PM
AMD option:
motherboard: Newegg.ca - GIGABYTE GA-890FXA-UD5 AM3 AMD 890FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard
processor: Newegg.ca - AMD Phenom II X6 1090T Black Edition Thuban 3.2GHz 6 x 512KB L2 Cache 6MB L3 Cache Socket AM3 125W Six-Core Desktop Processor HDT90ZFBGRBOX
video card: Newegg.ca - PowerColor PCS+ AX5850 1GBD5-PPDHG2 Radeon HD 5850 (Cypress Pro) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card
RAM: Newegg.ca - Crucial 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Desktop Memory Model CT2KIT51264BA1339
Total: $ 1122.92 that includes shipping and price of items before tax.
INTEL solution:
processor: i7-930 Newegg.ca - Intel Core i7-930 Bloomfield 2.8GHz 4 x 256KB L2 Cache 8MB L3 Cache LGA 1366 130W Quad-Core Desktop Processor BX80601930
motherboard: Gigabyte x58a ud5 Newegg.ca - GIGABYTE GA-X58A-UD5 LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Video card: powercolor 5850 game included: Newegg.ca - PowerColor PCS+ AX5850 1GBD5-PPDHG2 Radeon HD 5850 (Cypress Pro) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card
RAM: corsair 3X2GB memory: Newegg.ca - CORSAIR DOMINATOR 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMP6GX3M3A1600C8
Total: $1140.91
Do I need a different cooling solution for the intel? i read that the stock cooler is crap.
So which do you guys say is best for me from these two options?
Remember, I will use it for movies, and virtualization (5 virtual machines running at once using hyperv and microsoft r2 2008 server), and i picked that video card because it includes a game for free.
Old August 11, 2010, 08:50 PM
how about 870a+1055t and a 5870? see what the total is then :)
edit. for intel the ud3 will save you a good 50-70 buckers
Old August 11, 2010, 09:23 PM
martin_metal_88's Avatar
Avoid crucial memory like the plague! also look at 1600Mhz if you want to oc. G.skill, corsair ( not the CVS series ) Patriot and mushkin are the way to go for memory, many of us here love G.skill. You will also have to look for a CPU cooler. Coolermaster Hyper 212+ is cheap and allow good OC.
New Build- Corsair 800D --> My cleanest build ever. Watercooled btdvox Case Mods, Worklog & Gallery 28 May 11, 2010 01:07 PM
Windows 7 Build 7000 VS Windows XP SP3 Build 2600 Benchmarks Veritas Overclocking, Tweaking and Benchmarking 3 March 3, 2009 02:48 PM
