Old August 14, 2010, 02:58 AM
Ok guys, here is what I am thinking of purchasing, would love to hear opinions on which way to go, intel or amd, which would you choose based on the items below?
here is what i am ready to pull the trigger on:
Intel solution:
video card: 298.99+11.49
Newegg.ca - XFX HD-585X-ZNFC Radeon HD 5850 1GB 256-bit DDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card w/ Eyefinity
combo ram/mobo:799.98
Newegg.ca - Computer Parts, PC Components, Laptop Computers, Digital Cameras and more!
processor:303.97+4.99
Newegg.ca - Intel Core i7-930 Bloomfield 2.8GHz 4 x 256KB L2 Cache 8MB L3 Cache LGA 1366 130W Quad-Core Desktop Processor BX80601930
Any suggestions on cooling solution that uses air?
AMD build:
RAM:499.99
Newegg.ca - Patriot Viper II Sector 7 Edition 12GB (3 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model PV7312G1600ELK
Motherboard:189.99+12.99
Newegg.ca - GIGABYTE GA-890FXA-UD5 AM3 AMD 890FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard
processor: 315.99+4.99-10.00(coupon)
Newegg.ca - AMD Phenom II X6 1090T Black Edition Thuban 3.2GHz 6 x 512KB L2 Cache 6MB L3 Cache Socket AM3 125W Six-Core Desktop Processor HDT90ZFBGRBOX
Video card:298.99+11.49
http://www.newegg.ca/Product/Product.aspx?Item=N82E16814150494
again, suggestions for air cooling?
Old August 14, 2010, 03:23 AM
Keltron 3030's Avatar
IMHO Dont go with that video card. pick uip one with an external exhaust like this: NCIX.com - Buy XFX Radeon HD 5850 725MHZ 1GB GDDR5 4.0GHZ 2XDVI HDMI Display Port DIRECTX11 PCI-E Video Card - HD-585A-ZNFC In Canada.
Also, that ram wont work with the AMD build. you need dual channel memory for the AMD, but what you got there is triple channel
Also I agree with the CM Hyper 212 for a good heatsink. just make sure to pick up some good fans as well
FFFFFFFUUUUUUUUUUUU-
Old August 14, 2010, 03:32 AM
ok, stupid question, but it is DDR3 RAM right? which does work with amd am3 890fx chipset.
So does it matter if they call it tripple channel kit? all it is is 3 identical sticks, hence "tripple channel kit".
Or am i missing something here?
and dual channel is like 2 identical sticks of RAM.
right?
Old August 14, 2010, 07:41 AM
DDR3 is the only thing that works on the 800-series chipset, HOWEVER IT MUST BE DUAL CHANNEL!!!!!!
if it says triple channel, it wont work with AMD systems
and yes dual channel is 2 sticks of ram
New Build- Corsair 800D --> My cleanest build ever. Watercooled btdvox Case Mods, Worklog & Gallery 28 May 11, 2010 01:07 PM
Windows 7 Build 7000 VS Windows XP SP3 Build 2600 Benchmarks Veritas Overclocking, Tweaking and Benchmarking 3 March 3, 2009 01:48 PM
Critique my gaming build build 1080p New Builds 10 January 14, 2009 03:18 PM
